98 Ranger front suspension issues
Old Jun 19, 2008 | 06:43 PM
nmcqueen469's Avatar
nmcqueen469
I just bought a 98 ranger, 2wd 5-speed. The inside of the front tires are pretty tore up, looks like both tires have some inward camber at the top, the front end shakes pretty badly at 60-70mph. It also makes a growling noise between 33-38mph.
Any suggestions on where to start? Ball joints? Wheel bearings? U-joints? Thanks in advance for the help.
Old Jun 19, 2008 | 07:15 PM
mfp4073's Avatar
mfp4073
any of the above. Jack it up on stands and start muscling the wheels. If you have someone else that can muscle while you watch that would be better.
Old Jun 19, 2008 | 09:20 PM
hydro_37's Avatar
hydro_37
Tie rod ends.....ball joints and wheel bearings could all be possible sources.
Old Jun 20, 2008 | 07:35 AM
customstringer's Avatar
customstringer
To me those are classic ball joint issues and though you don't mention mileage at that vintage they could well be due. A common check is to have the wheels 3-4 inches off the ground with wheels still on and push-pull at top and bottom to check for movement. Or, raise truck same way and use pry bar as lever from bottom, pull up against tire and check. If you are going to do them, do all four because once one or two goes the others are not far off. I also agree it could be the other components mentioned but from my experience the ball joints are the first culprits on Rangers.
Old Jun 20, 2008 | 05:11 PM
hydro_37's Avatar
hydro_37
Ball joints on ALL Ford trucks suck. When you replace them make sure to use greaseable ones like Moogs.
Old Jun 20, 2008 | 05:17 PM
Greywolf's Avatar
Greywolf
Camber can also be influenced by weak spring coils. But it isn't quite old enough unless it got POUNDED by a prior owner.
Keep in mind also that a master bushing kit is good to have around.
Old Jun 21, 2008 | 10:55 AM
CougarXR02's Avatar
CougarXR02
I agree with everything said. I would suggest doing all ball joints (both upper and both lower), Tie Rod ends, good time to do Sway bar end links, and while you have it apart front brakes with new rotors and bearings while you're in there are probably in order. Given your symptoms look for the upper control arms with ball joints as one assembly as my creaking and groaning was coming out of the control arm bushing.
Seems like a lot of things, but total is only around 300 bucks and you'll be good to go for years to come in one days work.
Old Jun 21, 2008 | 03:54 PM
customstringer
Someone correct me if I'm wrong, but if you do the ball joints, tie rod ends and/or some of the other components, are you not are looking at a front end alignment to finish the job.
Old Jun 21, 2008 | 07:17 PM
hydro_37's Avatar
hydro_37
Yes you are.
Old Jun 21, 2008 | 09:44 PM
nmcqueen469
Thanks for all the input. Getting it up on a lift tomorrow to do some inspection. By the way, it has 135K miles.
Old Jun 23, 2008 | 03:22 AM
CougarXR02's Avatar
CougarXR02
absolutely agreed. I often assume a lot when i type. lol. but yes, I use the couple of reputable dealers around here to do alignments, $60-70.
AmericanMade
Feb 12, 2012 10:06 AM
Stretchstick
May 1, 2009 04:13 PM
Kj1998Ranger
Feb 22, 2005 08:43 PM
dbradey
Jan 17, 2004 11:44 AM
rellik74
Nov 16, 2002 12:20 AM
