curb weight
Old Feb 8, 2004 | 08:02 PM
kermit's Avatar
kermit
Talking curb weight
hi all....gotta question. what would the approximate curb weight of a '73 F250 w/460 be? have to tow it to california at the end of the month with a towbar, and need to have an idea of the rolling weight.
thanks for any help.
jamie
Old Feb 8, 2004 | 09:27 PM
ejustin3724's Avatar
ejustin3724
The weight should be posted on the door. I think about 3000+. Remenber to tow with a bigger truck then your towing. What about a trailer? It would be alot easer.
Old Feb 8, 2004 | 09:29 PM
kermit's Avatar
kermit
well, i have to use a rental truck (penske, 25 ft with a diesel motor) but according to them, the truck is both too heavy and wide for a car dollie, and too long for a trailer. so i figure i will just hook up old reliable(tow bar) and get her there that way.
Old Feb 8, 2004 | 09:34 PM
ejustin3724
You souldn't really notice it behind the big truck. Also you shouldn't have any trouble with it wipping. Heck you may even beable to use the space and load your truck.
I'll wave when you pass through olympia. Good luck!
Old Feb 8, 2004 | 09:37 PM
ejustin3724
are you going to remove the driveline?
Old Feb 8, 2004 | 09:56 PM
79Indy's Avatar
79Indy
Just for reference, my '79 150 which is 2WD, Long Bed, w/302-C6 has an actual measured wieght of 4,180lbs. It seems like a 250 with a 460 should be a few hundred pounds more.
Old Feb 9, 2004 | 12:02 AM
kermit's Avatar
kermit
yeah, i am gonna disconnect the driveshaft at the rear end and throw it in the back of the moving truck....same thing i did when i towed my ranger from illinois to washington
Old Feb 9, 2004 | 12:07 AM
FordPickup460's Avatar
FordPickup460
My 77 F150 4x4 with a 460 (pics in gallery) weighs 5000 lbs. i used truck scales at a gravel pit.
Old Feb 9, 2004 | 02:13 AM
Matts72's Avatar
Matts72
My F150 2wd, 351M, C6 weighs in at 3950 lbs, with a tool box, but a steel airgate instead of a tailgate.
A 4x4 version weighs in at 4400 lbs. I'd add 350 lbs for the bigger motor.
Old Feb 9, 2004 | 05:39 AM
F150daniel's Avatar
F150daniel
79 F100, 302, C4
when I go the the scales at the landfill, its around 4,700 lbs, but i do have stuff in the bed, stuff behind the seat, and two people.
Old Feb 9, 2004 | 01:58 PM
Monster 78 F-150 4X4's Avatar
my 78 f-150 4x4 with a 460 clocks in @ 5100# with a full tank of fuel and its a short bed with me in the truck its about 5250# that is what all the scrap yard slips I have laying around says
Old Feb 9, 2004 | 02:48 PM
jcs17's Avatar
jcs17
My old 78 F250 had a curb weight of 5200 full tank bone stock. My current F100 short bed weighs in at 4100. Both are 460 c-6 trucks.
Maj spoons
Mar 26, 2010 08:32 AM
tippmann87
Dec 28, 2007 11:51 PM
Silver02
Aug 16, 2005 12:10 PM
Dunk
2004 - 2008 F150
20
Nov 9, 2004 02:19 PM
hpguy
Dec 29, 2000 04:10 PM
