expediton crazy light flashingchimes ringing
Old Feb 8, 2004 | 07:12 PM
mountainman101's Avatar
mountainman101
i took my car to dealer blower fan came on with car being off 3 times in two months it killed the batery every time they said it was the batery they changed it then air bag light came on flashed then stayed on every 25 to 30 minutes the awd 4+4light comes on rings a chime and goes off the light for the over drive flashes all the time now i went through a couple of big pudles but iam lost as what to do afraid to go to dealer now the drvers window worts only sometimes help
Old Feb 8, 2004 | 07:50 PM
FTE Herman's Avatar
FTE Herman
Are you a religious man? An exorcist may be required. Seriously though, it sounds like the GEM. Some applications had water leaking from a bad windshield gasket. What's your year/model?
Old Feb 8, 2004 | 08:19 PM
mountainman101
1998 xlt expedition
Old Feb 9, 2004 | 08:54 AM
maddindian's Avatar
maddindian
My 97 just started having a similar problem, taking it to the shop in a few days what is the GEM .
Maddindian
Old Feb 9, 2004 | 09:52 AM
mountainman101
re gem module
its a computer type part that controls alot of the electrical stuff iv'e been told that some expeditions have a windsheild leak that drips on the gem module check that you may have to do it twice its costly this forum knows a lot more than the 3 dealers i tried i always get good advice here some of these guys must be crackerjack mecanics they know so much it behind the fuse box good luck
Old Feb 9, 2004 | 06:50 PM
FTE Herman's Avatar
FTE Herman
Mountainman my dear sir, given your make/model/year I'm guessing its the problem I described. I can't guide you on the fix, as I haven't encountered the problem in person. I'm only recalling what I read here.
Old Feb 9, 2004 | 08:06 PM
maddindian's Avatar
maddindian
Does the GEM go by a different name, the guys at my local parts house can't seem to get it to pull up in their system, but the dealer with gladly sell me one for $200
Old Feb 9, 2004 | 08:23 PM
sucktin's Avatar
sucktin
You won't be able to get one aftermarket other than the dealer...just like wiper modules, abs modules, central timers, etc... The software in those is proprietary and even in production they are expensive so service will be VERY expensive. FYI GEM stands for Generic Electronic Module...very high-tech name!!!
mab6680
May 11, 2010 01:23 PM
adamzelazowski
Feb 5, 2009 01:31 PM
mikehalll
Jan 12, 2007 09:26 AM
Birds 05 F-350
Sep 15, 2005 08:23 PM
Ranger3L
3.0L V6
16
Apr 28, 2004 05:06 AM
