Need help with wiring layout
Old Feb 8, 2004 | 02:32 PM
tomf52's Avatar
tomf52
Unhappy Need help with wiring layout
I Keep getting the trouble code P1506. According tto the OBDII list on this site, the IAC is bad or the IAC circuit is going to ground. Replaced the IAC and made no difference. Now need to know the pin numbers at the computer to check the wiring. It's a 1998 2 WD 2.5 cyl four banger with A/C. Any help would be greatly appreciated. Thank you.
Old Feb 8, 2004 | 04:18 PM
Rockledge's Avatar
Rockledge
Powertrain Control Module (PCM), 2.5L
Pin 36 (T/LB) = Mass Air Flow Sensor Return
Pin 88 (LB/R) = Mass Air Flow Sensor Input
Old Feb 8, 2004 | 05:24 PM
Dave257's Avatar
Dave257
IAC Control
Ford Says;
P1506 - Idle Air Control (IAC) Overspeed Error
This DTC is set when the PCM detects engine idle speed that is greater than the desired rpm.
Possible troubles
IAC circuit short to GND
Damaged IAC valve
IAC valve stuck open
Vacuum leaks
Failed EVAP system
Damaged PCM
Test
Disconnect IAC valve and look for little or no change in engine rpm as an indication of a stuck or damaged valve.
PCM (2.5L) Pin 83 White/Light Blue
Other side of IAC goes to red +12vdc.
Dave
Old Feb 8, 2004 | 07:10 PM
Rockledge's Avatar
Rockledge
Sorry about the info on the MAF, must have been daydreaming.
My '98 Ford Manual says the same thing that Dave posted:
PCM (2.5L)
Other side of IAC goes to Red +12v
earlybirds
Sep 19, 2007 06:34 PM
Crazz
19
Aug 7, 2004 10:45 PM
chanroy
Aerostar
Jan 4, 2004 08:08 PM
creature66
Sep 3, 2003 10:21 AM
PAUL_2
Mar 27, 2002 05:39 PM
