Still have rough idle on my 1989 5.8L, have cleaned the IAC. If I unplug it the engine dies quick. I have read many of the old posts and some say when you unplug it the engine should die quick and that is normal, other say that the engine should shudder a little while and then die. Does anyone know for sure what should happen when you unplug it and how to tell if working correctly, Thanks Mike
i have a 1993 5.8 cant get rid of the bad idle .if i unplug my air by pass solenoid, the motor will slow down to about400 rpm but would not die.hope i find what is causing this
If you unplug the IAC and it doesn't stall, you have an air leak somewhere. Most likely the upper manifold is leaking where it sits on the lower manifold, common problem.
hey i agree rough idling 5.8 as a forum . i have sprayed carb cleaner all around lwr /upper intake and still came up empty ,tryed vacumm connections,had 2 diffrent shops try and locate they came up with either ecm or injectors .i figure the last owner gave up and sold it i may just do the same. scott
As soon as I get the chance I am going to pull the new ICM I put in and replace it with the old one and check if the idle is still bad. It idle gets good again it is the new icm, possible different programing.
Mike
when you unplug the iac it should not stall. the rpms should drop to like around 400. if your engine wont start with the iac unplugged then you need to set your hard idle. just turn the throttle stop screw a little and keep trying to start the engine. stop adjusting the screw in when the engine starts and just barely idles. now plug in the iac and your hard idle is set.
