Monster gas tank installed!
Old Feb 7, 2004 | 09:15 PM
gtex's Avatar
gtex
67/69 Project update.
The bed is now on the truck, and I installed the 90 gallon gas tank that was in the 69 before in the bed. I've got it plumbed up and even installed a sending unit that is supposed to match my aftermarket guages.
I let the tank sit for a while, knowing it would get dirty and rusty, but I had to let it breathe to feel safe cutting the hole for the sending unit. After making the hole, I poored two quarts of CLR into the tank, and filled it with my 2600 PSI pressure washer and drained it. Then I poored an entire gallon of Berrymans Carb cleaner in the tank and washed it around as best I could. It's a bit hard to "shake it up" being a 90 gallon tank.
The gauge moved with the ignition on, a good sign. I then proceeded to put $100 on gas in the tank. It's Super, at about $1.70 gallon. I figure I got about 55-60 gallons.
The gauge moved to almost a 1/4 tank :-) I knew this was coming, since the tank is L-Shaped. I can adjust the sending unit float arm a bit longer, that will help some. But, the shape of the tank means I'm going to have a healthy last 1/4 tank.
In any case, it's good to have some more weight over the wheels. I need the traction. The FE446 is running pretty good. Still some intermittent power loss. But it really hooked up on the last Dyno. Showing over 400lb-ft of torque at the rear wheels from about 2600-4800RPM :-) This through a C6 auto and a Dana 60 rear.
for those not familiar with the project:
http://www.thedreyerfamily.com/69f25.../67project.htm
some pics of the tank before, when running on the 69.
http://www.thedreyerfamily.com/69Gas.htm
The tank doesn't look as pretty white now. It needs paint, but I'll do that when I get the truck painted. I should be able to go more than 150 miles now. The last measurement was 8 MPG....I wish gas prices would go back down :-(
Old Feb 7, 2004 | 10:24 PM
fordman428's Avatar
fordman428
it looks great greg, the truck looks awesome as well, i like them white faced gauges. i wish gas prices would go down also i will be broke once my trucks running. keep up the good work.
Old Feb 8, 2004 | 11:00 PM
rebocardo's Avatar
rebocardo
What do you use to hold that tank down? Is it bolted directly to the frame (probably hits 650+ pounds full)?
Old Feb 9, 2004 | 01:05 PM
gtex's Avatar
gtex
Embarassed..there are currently (2) 1/4" bolts holding the tank to the bed. There are 2 more mounts at the front of the tank that I have not made holes for. It doesn't move easily when empty, much less full!
I'll probably run a strap as well after I put a tool box over the inside part of the "L".
I doesn't appear to be stressing at all now. It sure helped with the traction :-)
Old Feb 9, 2004 | 04:20 PM
mypa'struck's Avatar
mypa'struck
That's a nice little reserve, should get you to the next gas station. You might need to take out a loan to fill it up, especially if gas prices keep going up. 8 mpg is pretty good with that motor and that much weight.
BTW, I love your exhaust setup. Those are neat looking headers, and I like the cut-outs. I played the .mov file, was the exhaust plumbed when you taped that? Engine sounds awesome. I bet your neighbors love you.
Old Feb 9, 2004 | 05:18 PM
gtex's Avatar
gtex
The audio files posted are actually very bad. They are also with open headers. I need to get a good recording device to sample the new sound.
As I hoped, the 4 pipes create a nice harmony of exhaust notes. It really sings between 2000-3000rpm. below that it's a bit like your typical Flowmaster sound. Above 3500, it's just mean.
With the cut-outs open, it's mean and loud as expected.
Tomahawk
135
May 28, 2016 05:39 PM
annaleigh
Oct 18, 2015 10:42 AM
gtex
22
Feb 17, 2006 12:46 PM
gtex
Mar 12, 2004 07:43 AM
gtex
17
Feb 13, 2004 07:10 AM
