Fabricated Aluminum Valve Covers installed/Pics
I finally go the fabrictaed Aluminum Vave Covers installed.
See pics at the bottom of the project update web page:
http://www.thedreyerfamily.com/69f250/projectupdate.htm
Here is the long, mostly sad story on these. For those of you tempted by theme on Ebay.
The bolt holes are only 1/4", and require 1/4" bolts. Your heads will have 5/16" threads. You will have to purchase 1/4x20 heli-coil inserts to make these work. You will need to chase the currrent threads with the heli-coil supplied tap. (My tap didn't clean out enough material to easily install the hel-coils. Once I got the threads chased out, I installed the heli coils. Note, once in stalled, these are a bear to remove, especially if you go as deep as needed.
Now the inserts are in place the for first time. The bolts provided were too long. These are a very specific style allen socket head style machine bolt. If you don't get the right head, it will not go into the valve cover as intened and would look wrong in my opinon. You probably won't find one at the local hardware or auto store. Anyway, I needed shorter bolts. I luckily did find 6 at the local Ace Hardware (my local store carries an exceotional amount of fasteners. 4" is the perfect length. That's 1/4" shorter than those provided. So, I was able to finally install the passneger side. I had to wait for mor bolts. They never got them, I went to American Bolt here in AUstin. They had what I needed.
You will also have to cut an opening in the valve coves if you want to install a breather, oil filler or PCV. You can cut this hole with a drill press and a bi-metal hole saw (guess I needed those anyway). Note, A 1 1/8" hole saw, will make more of a 1 1/4" hole. I made it work with some gasket sealer. There are no baffles on the inside of the cover. Order some baffled grommets from Summit or the like.
Now that I had the bolts figured out and the holes made. I had to jack/joist up one side of the motor to install the bolts if you have the larger brake booster.
I'm happy with the look. And the passenger side has been running for a whil, and appears to be sealing. But, this is by no means a typical valve cover install.
If you got this far, thanks for reading my novel.
Originally posted by 76supercab2
Looks good. One question. Why couldn't you just shorten the bolts that were supplied as too long?
I also had to insall a piece of 3/4" heater hose around the bottom of the PCV to fit in to the baffled grommets. I don't remember other grommet sizes being available with baffles.
It's about an inch from the brake booster. A little ttricky to get the cover in place. make sure to have the bolt already in the valve cover if possible or you get to hoist/jack up that side of teh motor. I was already setup to do this, since I'm replacing the pump shaft.
ALso, warn others that the grommets are baffled. They my try to poor oil in there and get a surprise :-)
MAK347
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
58
04-19-2018 10:50 AM
scrambledlife
1997-2006 Expedition & Navigator
16
08-23-2015 06:39 PM
JuanHuevos
05-18-2015 01:38 PM
palmercomputes
15
12-27-2006 11:36 PM
