Fuel pump relay
Old Sep 22, 2005 | 09:11 PM
  #46
ymtrebel806's Avatar
ymtrebel806
yes i have an 87 ranger 2.9 v6. and 87 xlt you say there isnt any gem on it?
Old Sep 22, 2005 | 09:51 PM
  #47
Rockledge's Avatar
Rockledge
No GEM on your '87, they didn't come along until about '95 or so.
Old Sep 26, 2005 | 07:11 PM
  #48
ymtrebel806
where does the power come from that goes to the eec relay and the fuel pump relay? also is the relay supposed to make a clicking noise when i turn the switch on?
Old Sep 26, 2005 | 08:21 PM
  #49
Ken00's Avatar
Ken00
On my 1989 they are powered from the power distribution box, fuse 8 & 1, but I don't think you have a PDB so then it would be fusable links.
Anyone have an 87 wiring diagram?
Old Sep 27, 2005 | 12:54 AM
  #50
87 XLT's Avatar
87 XLT
Yep, i've got one. Ignition switch to EEC relay is red/light green. Starter relay -red fuse link- to EEC relay is yellow.
For the pump relay: Starter relay -blue fuse link-to pump relay is also yellow.
EEC relay to fuel pump relay is red,
And yes the relays should click when you turn the key on.
Old Sep 27, 2005 | 07:10 AM
  #51
pawpaw's Avatar
pawpaw
The power to energize the relays, comes from the ignition switch.
So if they are not working, 87XLT will have to give you the color codes for those wires, so you can check for voltage coming from the ignition switch, to the relays operating coils.
Old Sep 27, 2005 | 11:10 AM
  #52
wtroger's Avatar
wtroger
Ground the fuel pump test pin on the eec test plug and turn on the ignition switch the pump should run. If it does then check to make sure you have voltage at the PCM. The pcm does nothing but turns on ground for the FPR circuit I think it is a yellow with green stripe wire I don't have my books here to give you the pin outs on the pcm. If there is no voltage there then it is a wiring issue if there is voltage it is a pcm issue. I have a mustang I have wired that circuit up to a switch because the PCM FPR circuit is bad.
Old Sep 27, 2005 | 07:16 PM
  #53
ymtrebel806
ok well a couple days ago i was checking some things out and trying to clean up all the ground wires i could find. but heres the problem now well acouple days ago i left my switch on for like 10 minutes or so and i was looking around and found out that my alternator was hott. is it supposed to get hot like that with just the switch left on? well today i went out and tried to check that out like wtroger said but now i am not getting any power in the cab at all. the battery is good i put it on the charger and its fully charged, i also checked to see if anything was going in with the charger on and still nothing. so then i checked and im getting power too the relays and the one does click when i put the battery terminal on. so ummm...... now what? lol
P.S. does anyone have a distributor drive gear? (the gear on the end of the shaft?)
Old Sep 28, 2005 | 02:01 AM
  #54
87 XLT's Avatar
87 XLT
To check the fuse links turn the ignition switch to run. Are the idiot lights on.
Try the headlights, do they work?
Old Sep 28, 2005 | 06:36 PM
  #55
ymtrebel806
hello when i put the battery terminals on the battery light inside in the dash comes on but is real dim and when i turn the switch over it goes out. but the battery isnt dead cause i have noticed if i let the terminals on the battery has been going dead so i charged it up and checked it with my meter and its fine. but anyhow the lights dont come on neither does the dome light or anything.
Old Sep 28, 2005 | 09:27 PM
  #56
wtroger's Avatar
wtroger
disconnect the big plug on the alternator i think you have a short some where in the electrical system and the only way the alternator can get hot is if a diode has gone short.
Old Sep 29, 2005 | 07:14 AM
  #57
pawpaw's Avatar
pawpaw
Yup, sounds like you might have a shorted diode in the alternator.
Why not pull this puppy & have a no cost bench test done, at your favorite autoparts store.
Let us know what you find!!!!
Old Sep 29, 2005 | 11:30 AM
  #58
87 XLT's Avatar
87 XLT
So thats what the problem is, a shorted diode. Good info to know.
Note to self on page 16 of my EVTM: Hot alt equals shorted diode.
Old Sep 29, 2005 | 08:26 PM
  #59
ymtrebel806
alright thanks guys ill have it checked out this weekend ill get back to ya and let you know what i find out about it
PEG
1997 - 2003 F150
Oct 20, 2014 11:54 AM
Alto
29
Jul 6, 2013 10:16 AM
larrylass
Electrical Systems/Wiring
Sep 24, 2010 06:34 PM
piersol
Feb 3, 2010 08:12 PM
rickh6155
2004 - 2008 F150
Dec 17, 2008 01:31 AM
