Fuel pump relay
Old Feb 7, 2004 | 09:08 PM
Ken00's Avatar
Ken00
Sorry, can't help with that, my 1989 had the power distribution box, no fusable links.
Old Feb 7, 2004 | 09:19 PM
chucknc's Avatar
chucknc
Thanks anyway.
Old Feb 7, 2004 | 10:27 PM
87 XLT's Avatar
87 XLT
Looks like your getting lots of good feedback here. That code 96 makes me think that this "might" be wired similiar to my 95 Taurus. If thats the case the fuel pump relay is wired to a 3 way splice with with one leg going to the powertrain control module/PCM
& from there to the inertia switch & then to the fuel pump. So if this was a 95 Taurus I would be looking for an open in the yellow wire between the splce & the PCM.
Old Feb 7, 2004 | 10:41 PM
chucknc's Avatar
chucknc
The feedback I'm getting here is what makes this site such a great resource. The wiring sounds similar. I'll get back on it first thing in the morning and let you know.
Thanks for all your help,
Chuck
Old Feb 8, 2004 | 12:14 AM
87 XLT's Avatar
87 XLT
OOPS, i just looked up that 96 code "Fuel pump circuit open, battery to ECA" not "PCM" When you turn the key to run the ECA grounds the fuel pump relay. Is that happening? Strange that you would get that code AND not be able to get the pump running when you provide the ground at the self test connector?
Old Feb 8, 2004 | 12:29 AM
chucknc's Avatar
chucknc
Strange seems to be the norm with this van. I'm not real confident that I made a good connection on the self test connector, I'm going to try again. The fuel pump relay clicks when I turn the key to run just like it does when I ground the self test connector whether or not the relay has power going through it I'm not sure
Old Feb 8, 2004 | 12:40 AM
87 XLT's Avatar
87 XLT
Yeah, like the other guys mentioned check for power at the inertia switch. Gotta love this forum, i'm learning, you're learning, we are all learning how to fix these miserable/PITA problems.
Old Feb 8, 2004 | 09:55 AM
Ranger GT2's Avatar
Ranger GT2
Do you know if the power is actually getting to the fuel pump connection on top of the fuel tank. We had a 1988 aerostar van that actually did the same type of thing. Fuel pump relay would make noise but the engine would not start. I put in a new fuel pump thinking it was bad, but noticed that the wire connection had corrosion on it (rivet holding connector and wire on fuel pump assembly plate) not allowing voltage to get to the fuel pump itself. Once the connector was corrected the van ran fine. The only way to check this though is to drop the gas tank.
Hope this helps - but hope you don't have to drop your tank to find out.
Old Feb 8, 2004 | 10:24 AM
chucknc's Avatar
chucknc
I don't think power is getting to the fuel pump but, I really hope the problem isn't AT the fuel pump since I filled up the day before this problem started
Old Feb 8, 2004 | 12:44 PM
Rockledge's Avatar
Rockledge
To test the pump itself, try jumping 12v directly to it, bypassing the relay. Then try bypassing the inertia switch. You can use a long jumper wire off the battery, if you need to...
Old Feb 8, 2004 | 01:05 PM
chucknc's Avatar
chucknc
To bypass inertia, would that be battery(+) to PK/BK?
Old Feb 8, 2004 | 01:35 PM
Rockledge's Avatar
Rockledge
Yes.
Old Feb 8, 2004 | 02:29 PM
  #28
chucknc's Avatar
chucknc
OK. Bypassed inertia, Power to pump,WHEW!!! Not getting power to inertia & still can't rum pump through self test connector. Going to try bypassing FPR, then check fuse link. I'll get right back to ya'll.
Chuck
Old Feb 8, 2004 | 03:08 PM
  #29
chucknc's Avatar
chucknc
Thumbs up
Well, turns out it was the fuel pump relay after all. $10 part - 10 second fix. The other one wasn't that old so I just KNEW it couldn't be that. Just goes to show you, Keep It Simple Stupid. Thanks to you guys, I now know more about this van than I really wanted to. If I have a similar problem, I now have all of the tools, techniques, and info to fix it in minutes instead of days. I'll check back on this site frequently in hopes I can share some of the love y'all have shown me.
Thanks ever so much,
Chuck
Old Feb 8, 2004 | 04:00 PM
  #30
87 XLT's Avatar
87 XLT
Glad to hear you got it fixed. You and I have both learned a thing or 2 about troubleshooting this sort of thing.
