Sponsored by: Real Truck
2000 F250 Front hub problems
Old Apr 22, 2002 | 10:00 AM
FIXAHONDA's Avatar
FIXAHONDA
I have a 200 F250 CC 4x4 lwb and on a hard parking lot turn the front end makes a knocking noise-seems like the hubs are locked but they are not-anyone have any suggestions?
Old Apr 22, 2002 | 02:34 PM
buffy's Avatar
buffy
Do you have manual hubs or the ESOF system? I have the ESOF and a couple times my hubs haven't completely disengaged. They make a clicking/thumping sound. I engaged/disengaged them a couple times and they eventually fully disengaged. You might try backing up, too.
Old Apr 22, 2002 | 04:20 PM
FIXAHONDA's Avatar
FIXAHONDA
Has the esof hubs and i tried backing up and engaging and disengaging 4x4 and it did not help
Old Apr 22, 2002 | 08:43 PM
4x4x4x4's Avatar
4x4x4x4
From what you describe it seems that the hubs aren't unlocking.Have someone look the axle u-joint rotation form the front of the truck at a safe distance.If the u-joints are rotating while the vehicle is moving then your hubs aren't unlocking.
It is normal for the U-joints to knock a bit during tight turns if the hubs are locked.
Old Apr 22, 2002 | 10:10 PM
fjlee's Avatar
fjlee
Old Nov 11, 2007 | 01:43 PM
dalton69's Avatar
dalton69
i have a 04 man hubs with mine and it just started doing the clicking noise, it almost sounds like something is rubbing in the front end. i have a 6 inch lift on my truck 35" tires. what is the fix do i have to replace the hubs. i tried locking and unlocking my hubs and it is still doing it. also i looked and my half shafts are not turning so they are unluck.
Skylaneman
1983 - 2012 Ranger & B-Series
Jun 21, 2015 09:45 PM
Primersthebestest
May 18, 2015 11:46 PM
troverman
Dec 16, 2014 06:41 AM
sand1
Sep 7, 2013 10:38 PM
PSDx3
Jan 21, 2011 10:25 PM
