Dome light switch on Ranger
Old Feb 3, 2004 | 10:15 PM
Diabolic's Avatar
Diabolic
I'm looking into buying a new dome light for my 1999 Ranger, because the one i have doesnt have a switch. I have the problem where when it rains, the dome light stays on even when the doors are shut. I've seen many posts about this but was more intrested in buying a new dome light with a switch. So, just thought i would share, if anyone has any comments, feel free. Thank you.
-Phil
Old Feb 3, 2004 | 10:31 PM
turbine's Avatar
turbine
The switches are located INSIDE the doors, not on the door posts. They are prone to failure and/or sticking--and when this happens the dome light will not go out even if the door(s) are shut tight. Inside door panel must be removed to investigate the problem--about 3/4 labor hour per door. One of my door switches failed on my 1998 Ranger during warranty period.
Old Feb 5, 2004 | 06:15 AM
Bob Ayers's Avatar
Bob Ayers
Not entirely true!!!
The switches are mounted on the latch mechanism in the doors.
Just spray the latch mechanism very liberally with WD-40, then
open / close the door a few times, and this will usually solve the
sticky switch problem.
Old Feb 5, 2004 | 06:27 PM
turbine's Avatar
turbine
Ranger Electrics
Thanks, Bob. If have a dome light problem again, I will try your approach.
scottrkind
1997 - 2003 F150
Jun 16, 2016 07:15 PM
mrstephs
Apr 16, 2016 08:13 AM
papazig4726
Mar 6, 2015 06:07 PM
Joe T.
Nov 8, 2011 05:29 AM
nassor
Oct 4, 2006 07:17 AM
