Trouble Code 32 - EVP
Old Feb 3, 2004 | 08:43 PM
cougar86's Avatar
cougar86
I've been experiencing rough acceleration which felt like the timing was not right. I checked the timing with the SPOUT connector off and it was at 10 degrees BTDC. I then checked the codes and pulled code 32 - "EVP voltage below closed limit". How can I test the EVP sensor or circuit to ensure it is functioning properly?
Old Feb 3, 2004 | 10:56 PM
EPNCSU2006's Avatar
EPNCSU2006
There are several tests to perform to pinpoint the problem. I would get a Haynes manual if you don't have one already - it has all the test procedures in it, and is easy to follow.
gshumate
Mar 19, 2017 04:17 PM
4.9LOldFordTruck
Dec 22, 2015 02:38 PM
wag53
Jun 11, 2015 04:25 PM
poffutt
1978 - 1996 Big Bronco
33
Nov 4, 2011 08:48 AM
theperson10
Jan 19, 2011 03:53 PM
