ABS lamp??
Old Mar 4, 2004 | 06:22 PM
  #31
sucktin's Avatar
sucktin
It's up to you if you want to pay $1400 so your ABS works properly OR drive carefully and pretend you live in the time before ABS even existed! They say you can't put a pricetag on a life, but no ABS is not the same as driving around with steel belts showing on bald tires, no brakes at all, or blown out brake lights. If your brakes work fine (other than the ABS) I would tell them to bag it and just drive safe.
Old Mar 4, 2004 | 07:25 PM
  #32
RSCHAP1's Avatar
RSCHAP1
I DO like driving better w/o the ABS, but would like to get it going...for resell if no other reason.
Old Mar 4, 2004 | 08:26 PM
  #33
99expyTN's Avatar
99expyTN
ouch.....$1400. I know that yellow ABS light is irritating, but for $1400 dollars I think I could get use to it.
Regardless, I looked in my service manual concerning the Hydraulic Control Unit (HCU...I'm assuming this is the pump) and it listed 3 tests to perform. If the code pulled was DTC 1095, it said replace the HCU. Otherwise, check the pump motor circuit. Pin 2 on the anti-lock brake control module should read 10 volts. Pin 1 should have a resistance less than 5 ohms. If it passes these two tests, replace the HCU. Otherwise, you have a circuit problem.
If it truly is the HCU, you might be able to replace it yourself. The replacement procedure in the service manual read easy enought, but I didn't go out and look under the hood to actually see where the HCU is located. If you do determine to replace it yourself, try Five Star Ford in Arizona. I've ordered parts from them before (I live in Tennessee) and they are typically about 1/2 the cost of my local Ford dealer.
Philip
Old Mar 5, 2004 | 05:15 AM
  #34
RSCHAP1's Avatar
RSCHAP1
THANKS for the responses!!!!!!
Old Mar 10, 2004 | 08:35 PM
  #35
RSCHAP1's Avatar
RSCHAP1
open?
Garage said that the pump had an "open loop" alarm...is that hydraulic open or electrical???
Old Mar 13, 2004 | 05:56 AM
  #36
RSCHAP1's Avatar
RSCHAP1
Open Loop??
I was wondering if the "self-test" at start up checks for hydraulic pressure from the pump or does it just check the electrical circuit. Does the "open loop" message refer to an open electrical connection, like the motor running the pump is not responding, or no brake system fluid pressure building like an impeller in the pump is shot???
OCMetalhead
Escape & Escape Hybrid
Dec 31, 2016 08:16 PM
nick57
Mar 29, 2012 09:37 PM
sammycooks
Apr 26, 2010 08:00 PM
heymrdj
13
Oct 28, 2008 03:34 PM
huitt24
2004 - 2008 F150
Feb 2, 2006 09:40 AM
