93 f150 302cid
Old Feb 2, 2004 | 12:01 PM
oldbuck's Avatar
oldbuck
93 f150 302cid
starts after cranking less than 1 sec when cold, may or may not start when warm, if does not start the oly waty to start it is to depress the gas pedal. also sometimes goes to a fast idle other times not. where do i start?
Old Feb 2, 2004 | 12:12 PM
blu's Avatar
blu
Best place to start is pull the engine codes.
Old Feb 2, 2004 | 02:30 PM
88n94's Avatar
88n94
Have the codes checked as mentioned. Also have the fuel pressure checked at the same time if convenient. From what i've observed this is a common cause of the problem you've described
ubereal2
Missouri Chapter
483
Jun 1, 2014 03:35 PM
daerhldgs2
Sep 29, 2008 09:57 PM
mjpmn
Aug 10, 2008 05:50 PM
SShank42
Bronco II
Feb 9, 2005 08:20 PM
Hammerhead
1983 - 2012 Ranger & B-Series
Feb 21, 2004 04:35 PM
