plug wire question
Old Feb 1, 2004 | 03:44 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
plug wire question
i am getting resdy to install a pertronics ignitor 2 electronic ignition module on my 59 f250.instructions say not to use solid core plug wires with it.ipreviously had installed a set of reproduction wires from concourse parts.would these be classified as "solid core"??
Old Feb 1, 2004 | 06:47 PM
57_ford's Avatar
57_ford
I think what they mean by solid core is realy copper core wires. Solid core wires have a very low resistance. Good plug wires should have around 300-600 ohms per foot. If you have solid core wires you might hear ticking noise in a radio or tv.
Old Feb 1, 2004 | 10:21 PM
ibuzzard's Avatar
ibuzzard
so do you think the reproduction stock wires are copper?i understood it to mean using solid core wires would damage the pertronix unit.i am trying to see if pertronix' performance wires will work on my 292.concourse parts, for some reason, only shows them working for1958,which i can't understand.thanks for the help.
Old Feb 2, 2004 | 07:38 PM
57_ford's Avatar
57_ford
I don't think your reproduction wires are solid core but I could be wrong. My original wires were and my guess is yours may have been as well. Simple way to tell is to pull a plug wire off and look at down at the center if you see copper wire that is wrapped and crimped under medel contact that attches to your spark plug. If it is a black wire than it is not solid core. The rite way to test this is to check the resistance with a ohm meter if it has resistance than you don't have solid core wires. If you can get peformance wires to fit you may be better off any way. I use a hp unversal plug wires that can be cut to lenth and I crimp my own end on, That way it fits the way I want it to. Hope this helps
49m47
Jun 8, 2014 07:05 PM
mtntop1
Aftermarket Products
Oct 1, 2013 09:28 AM
cts1954
Mar 11, 2013 03:01 PM
motorhead66
Jan 24, 2009 07:54 AM
jwergers
Nov 9, 2002 09:23 PM
