Sponsored by: Kumho
tire size question
Old Feb 1, 2004 | 11:45 AM
MIKE 351's Avatar
MIKE 351
tire size question
what is the largest size i can put on my 92 f250hd on 16x8wheels or how much lift to clear 315 75 16 with out looking cramped?thanks mike
Old Feb 1, 2004 | 02:25 PM
ncl's Avatar
ncl
My brother had a 92 f250 hd and he ran 36x12.5 swampers with a 3" body lift. He had to move the bumper out away from the truck a little to clear the tires when turning and they rubbed a little on the front leaf springs at full turn but only when turning left. He ran 16x8 wheels also. The truck definitley looked awesome with the big tires though. The 36's filled the fenders well even with the body lift.
Old Feb 1, 2004 | 10:36 PM
biz4two's Avatar
biz4two
That is about a 35" tire and you shouldn't need a lift at all. But, I would suggest using a 1"-2" lift for the front only. You know the kind most trucks use when they install a snow plow. This will basically level the truck out and you should not have any problems. No need to replace the shocks either. Of course this is said without knowing your backspacing on the rims.
Skyjacker and Superlift would be a good source.
Good luck...
Old Feb 2, 2004 | 11:19 AM
kevinrf250's Avatar
kevinrf250
I have a 2" add-a-leaf on the front of my truck and have 285/75R16 tires. They look great, but they hit the bumper alittle when four wheeling, either shim the bumper or cut a little off of it. I cut a little off and you can't even tell looking at the truck. I think you would need a 4" lift to clear the 315/75R16's if you use your truck off-road.
Old Feb 2, 2004 | 01:36 PM
85351ho's Avatar
85351ho
right on kevin
Mike E.
May 25, 2013 05:07 PM
Mike Norwood
Feb 27, 2008 07:49 PM
mike L
Feb 10, 2006 09:51 PM
Drillinman
Dec 17, 2003 08:40 AM
topo4u2
Oct 13, 2002 12:21 PM
