Does anyone know if it is possible to add cruise control to a 77 F150 Ranger XLT 4x2 with a 460 and C6? If so where do I get parts and how do I do the conversion?
78-79 trucks and broncos had that option.
get everything the that touches the cruise control.
steering wheel cover, turn signal switch, speedo cable, amp (metalbox under the dash), wiring, everything under the hood.
it would be easyer to go aftermarket.
Ok where can I get these kits? And will a 78-79 steering wheel blot on in place of the stock one. Money is tight and I am willing to do alot of junkyard combing befor I am willing to shell out alot of cash.
The OEM stuff takes a little while to find all the parts but the quality is well worth the effort. Every aftermarket cruise unit I have tried have been complete junk and look like a kluge at best.
That sounds like alot of work. Are there anyaftermarket kits that are worth consideration? Or any other options? If not I think that I will just learn to keep a steady foot on those long trips.
I've done the swap and it's really not that bad. Gathering the parts was the worst part, and after a while it became a challenge that wasn't going to get the better of me. If you can find a donor truck that's complete you can scavange the parts in less than an hour and you'll be better equipped for the install.
Add the steering wheel and turn signal switch to the list of items needed.
oops! sorry i saw the stars and though it was the end of your post. Thanx guys for all you help, I'll have to think about what I should do but atleast now I know my options.
