Sponsored by: Auxito
1997 4.2l hard starting problem
Old Jan 31, 2004 | 08:49 PM
tom_strandberg's Avatar
tom_strandberg
i have read some of the other posts about this hard starting problem, so i will check out some of the things ican, the tps, the maf, and such just installed new plugs and wires! i am also installing a block heater, but i'm wondering what to use to pull out the frost plug its in there pretty good! also where should i drain the coolant from?? any help with this would be greatly appreciated! thanks!!
Old Jan 31, 2004 | 09:24 PM
Racerguy's Avatar
Racerguy
The drain for the rad is on the passenger's side back of the rad. It is a 3/4" nut looking thing. The block will drain when you pop the frost plug out......most of it will probably end up on you so wear eye protection etc.
To remove a frost plug you can use a screwdriver and hammer to tap in one corner of it. That will **** it in the bore then you can pull it the rest of the way out with Vise-Grips.
Clean the frost plug hole well with some fine sandpaper before you install the heater.
Old Feb 1, 2004 | 10:01 AM
tom_strandberg
thanks racerguy,
now i can finish, just wasn't sure how sensitive the frost plug was, but i'll give it a little american know how the BFHand if that still don't work i'll use bigger BFH, well i'll let ya know how all this works out see if it still starts hard! thank you
Old Feb 1, 2004 | 11:29 AM
BlueOvalFitter's Avatar
BlueOvalFitter
Yet,another reason why I live here in Florida. And with the temperature outside at a balmy 70*,life is good!
Old Feb 1, 2004 | 11:34 AM
Racerguy's Avatar
Racerguy
Yeah but you cant go snowmobiling in the bright sunshine today
nyah nyah
Old Feb 1, 2004 | 11:35 AM
LxMan1's Avatar
LxMan1
Warm, but salty air is hard on the vehicles.
Old Feb 1, 2004 | 11:43 AM
BlueOvalFitter
Been here since 1987......no rust problems or salty problems with any of the rides ive owned. And that 1984 GMC I sold last year,the one I came here to Florida in,still had the original paint on it; and NO RUST! Ya'll are just jealous because I am only 10 minutes away from the beach!
Old Feb 1, 2004 | 12:27 PM
Racerguy's Avatar
Racerguy
I'm about 15 minutes away from the beach.
Too bad it's covered in snow right now
Old Feb 1, 2004 | 12:43 PM
BlueOvalFitter
Wow,thats crazy! Snow on the beach! Ya'll have the best of both worlds; skiing on the water then on the beach!
A1C DiMaggio
Jan 26, 2013 09:07 PM
ford 5ver
25
Apr 11, 2009 08:55 PM
drem
35
Feb 28, 2009 09:31 PM
farmerf1
May 26, 2008 07:03 PM
1978fordf250
May 2, 2006 11:14 AM
