Blower motor quit
Old Jan 31, 2004 | 05:08 PM
pfogle's Avatar
pfogle
Blower motor quit
Hello, last night the blower motor just refused to run, I get it torn apart today to find all the fuses, and relays are good, but no power at the switch.. Any help will be greatly appreciated.
Old Feb 1, 2004 | 04:58 PM
pwood's Avatar
pwood
heater motor not running
I have the same problem. Have checked the blower motor. Runs fine. Fuses good. Switch appears good(did ohms test).
Right now have the heater hooked up to cig plug in.
Let me now what you find?
Old Feb 2, 2004 | 06:12 AM
pfogle's Avatar
pfogle
Mine was the motor itself had burned up. After we pulled it out you could smell the burnt brushes. It sounds like you may have a problem with the switch or wiring.... There is a fuse in the bottom of the fues box that controls the heater/a/c functions, it's 15 amp, and is in the very bottom of the face of the fuse box.. It's right next to the turn signal flasher hole.... Good luck, and let me know...
Old Feb 2, 2004 | 06:55 AM
pwood's Avatar
pwood
I have checked all fuses.
One for the blower and one for the a/c.
HELP!!! It is -18F here.
Old Feb 2, 2004 | 02:47 PM
pfogle's Avatar
pfogle
I would honestly try a new blower motor... It was only $45 at Advance Auto..... If its not allowing power to go through it, the switch won't work...
Old Feb 2, 2004 | 02:49 PM
pfogle's Avatar
pfogle
There is a power distrubution box under the hood. The very first 60amp fuse (just above 2 relays) is the blower motor that fuse may have blown.
Old Feb 2, 2004 | 03:03 PM
pwood's Avatar
pwood
This is besides the two by the driver's side door?
What else does this 60 amp fuse control?
Old Feb 2, 2004 | 04:19 PM
pfogle's Avatar
pfogle
What year is your van? The fuse only controls the blower, there is also a realy for the blower. Any of these could be bad. That is where I would start. Out under the hood there will be a fuse box with a lid on it.... If it's newer than an 88 or 89.. I forget exactly when they started using the power distribution box under the hood.
Old Feb 2, 2004 | 04:27 PM
pwood's Avatar
pwood
1997 Ford Ranger
checked the transmister in the heating duct. OK
I don't think I am getting any power to the switch.
Old Feb 2, 2004 | 04:53 PM
pfogle's Avatar
pfogle
That points to the resistor, relay, or that fuse under the hood.
Old Feb 3, 2004 | 06:16 AM
pwood's Avatar
pwood
That 60amp fuse must control more that just the blower motor?
Where is the resistor or relay located?
Old Feb 3, 2004 | 02:49 PM
pfogle's Avatar
pfogle
In mine (1992 E150 Van) that 60 amp fuse controls the blower motor only... There is a relay that is directly connected to the switch. Under the hood beside and under the brake master cylinder there should be a plastic box labeled "Power Distribution Box" you may need to look in your owners manual for the exact location as I'm sure it's different than mine..
mribbich
May 19, 2016 01:22 PM
drpratt
Apr 14, 2009 09:50 AM
homer4111
Jun 13, 2004 06:00 AM
jsconnor
Electrical Systems/Wiring
Jul 17, 2003 10:28 PM
