blower motor relay
Old Jul 12, 2003 | 04:20 PM
jsconnor's Avatar
jsconnor
blower motor relay
blower motor only works with a jumper. I found a relay bolted to the dash under the glove box, is there another one somewhere
Old Jul 12, 2003 | 05:21 PM
Torque1st's Avatar
Torque1st
Posting Legend
blower motor relay
Sounds like some custom wiring. There should be a blower resistor module that runs the blower at different speeds inside the HVAC duct. The blower speed switch is in the HVAC controls. Get an OEM manual from the online store here for some good wiring diagrams.
Old Jul 17, 2003 | 06:57 AM
F100_77's Avatar
F100_77
blower motor relay
I seem to be having the same problem with mine? it also has a relay located under the glove box like yours. What year and model is your truck? mine is a 1977 F100 Custom. Im sure you will get it fixed, There are alot of great folks who really now thier stuff on this forum, it's the greatest!
Nolan..
Old Jul 17, 2003 | 08:42 AM
73Custom's Avatar
73Custom
blower motor relay
Do you have a/c? If so, is it factory or dealer installed? Do you have power going to and from the fan switch?
Marty
Old Jul 17, 2003 | 08:49 AM
F100_77's Avatar
F100_77
blower motor relay
I know mine was factory intalled but, when I bought the truck someone before me had changed the 302 out to a 351C and removed the A/C. Any suggestions on what they may have disconnected that I need to look for? I will test to see if there is power coming from the fan switch as well.
Nolan....
Old Jul 17, 2003 | 10:28 PM
76 4x4 460's Avatar
76 4x4 460
blower motor relay
there is a resistor(reostat)that is mount to the heater plenum local parts stores do not service this item. Mine works w/a jumper like yours have not checked the dealers yet but jeffs bronco graveyard has alot of dealer items that are obsolete that will be the same as the trucks.
douglas.
1997 - 2003 F150
Jan 31, 2017 08:25 AM
Tnslider
Jul 1, 2015 04:00 PM
jmccann698
Feb 27, 2015 07:47 AM
ptrill
Nov 30, 2006 03:12 PM
pfogle
Feb 3, 2004 02:49 PM
