Atf
Old Jan 30, 2004 | 11:43 PM
buckford's Avatar
buckford
Atf
which type of ATF is not the color red so that their would be no fight if checked by the cops for untaxed fuel?
Old Jan 31, 2004 | 12:28 AM
Spectramac's Avatar
Spectramac
You wanting to put it in you fuel?
ATF is a horrible lubricant, better to try some stuff made for it. My local pump shop told me you'd be better off putting motor oil in your fuel anyway.
Old Jan 31, 2004 | 07:21 PM
buckford's Avatar
buckford
thats funny, cause dabuque injection inn iowa recommended it as a lubriciant and cleaner and said it would not hurt anything, now i am in limbo, don't know weather to use it or not, even though i heard many people do without ever having a problem. can you all post what your local shops say, or maybe your experiences with it. all info greatly appreiciated.
Old Jan 31, 2004 | 07:47 PM
Bob Ayers's Avatar
Bob Ayers
ATF is a great injector cleaner!! But the red color is a problem!!
Old Jan 31, 2004 | 08:28 PM
RawPower's Avatar
RawPower
What is it and how much do you put per gallon? How often?
Old Jan 31, 2004 | 08:32 PM
Bob Ayers's Avatar
Bob Ayers
WHen I service my Mercedes 300D, I fill the new fuel filter with ATF, which is enough to clean the injectors well.....
Old Jan 31, 2004 | 09:26 PM
ditch witch's Avatar
ditch witch
I've got a D2 and D4 Cat. I use 1 qt. per tank of fuel only once per year 'cause I don't run them alot.
If you're concerned about HP's checking your fuel, they usually inquiring at locations like weekly farm cattle auctions, and maybe a truck stop or two. I've driven a diesel powered car for 15 years and never stopped, asked or anything and it was totaled once (so they could have easily snooped then). BUT- they would have been wasting their time!!
Old Jan 31, 2004 | 10:36 PM
FSC's Avatar
FSC
I have asked many diesel technicians about using ATF in the fuel, most have said that it may do some good and it probably does no harm,
but there is no documented evidence that it does any good.
Old Feb 1, 2004 | 09:36 AM
TurboTuff's Avatar
TurboTuff
Every second tank of fuel I put a 1/2L of ATF(Automatic Transmision Fluid) in.
It keeps everything lubed and cleaned.
Works for me...
I have the jug in the cab to prove why the fuel is red.
I also have fuel receipts to prove where the fuel was bought.
Old Feb 1, 2004 | 11:59 AM
Shafer's Avatar
Shafer
Trailering
You are right. The best plan is to keep the aft under the seat if you get stopped. If you get a ticket, sending a fuel sample in for analysis will prove that it is ATF not dye.
Old Feb 1, 2004 | 12:25 PM
RawPower's Avatar
RawPower
Is there a specific type of ATF that your suposed to use?
Old Feb 2, 2004 | 08:43 PM
Shafer's Avatar
Shafer
Trailering
After talking with a few guys at different diesel shops they all say ATF should not hurt. The detergents should help but the friction modifiers may be an issue. So I asked them about 2 stroke oil and the overall verdict was very positive. Just pour it into the filter and head down the hiway. Or add it to the tank for everday driving. The discoloration will not be noticed.
Old Feb 4, 2004 | 10:05 AM
Spectramac's Avatar
Spectramac
I'll buy the cleaning aspect, but not the lube. Atf is very high detergent but does little to lubricate. I have seen people use a quart of atf in their engines and it does keep them spotless in side but I wonder what the bearings looked like? If you want to do it anyway I would just use dextron 3. The old type F is suppossed to have even less lubrication.
I think Shafer might be on to something with the 2 cycle oil. As a matter of fact I have a jug of CD-2 diesel additive at work that looks an awful lot like chainsaw oil. Hmmmm.
Old Feb 4, 2004 | 10:13 AM
Bob Ayers's Avatar
Bob Ayers
One good thing on my Mercedes Diesel, the injector pump does not rely on the fuel for lubrication, so the low sulfur diesel fuel was never a problem for it....
Old Feb 4, 2004 | 10:34 AM
adelyser's Avatar
adelyser
The B&M Trick Shift Synthetic is Blue in color. I used it in my car's engine when I first got it, and it cleared up a lot of problems.
