Atf
Old Feb 5, 2004 | 10:45 PM
Spectramac's Avatar
Spectramac
Mercedes? Did I jump to a different forum?
Old Feb 7, 2004 | 09:41 AM
nogo73's Avatar
nogo73
atf doesn't make it red enough for you to get a ticket and a simple anylises will prove its not dye is atf.
Old Feb 8, 2004 | 07:57 AM
cartwright's Avatar
cartwright
Just use Stanadyne Performance Formula and be done with it, Or If its just lubricity youre after, pour a can of Marvel Mystery Oil in the tank.
Old Feb 8, 2004 | 10:02 AM
Mike 84's Avatar
Mike 84
Why add ATF?If the diesel fuel you have been using was not providing enough lube the fuel system would of ate itsself a long time ago. Stop the nonsense!!!
Old Feb 8, 2004 | 10:11 AM
TurboTuff's Avatar
TurboTuff
Why you ask?
The fuel dries out the O-rings in the injectors!
The ATF keeps them from drying and cracking!
Before using the ATF I had to replace the O-rings twice.
Since using ATF I've replaced O-rings ZERO times!!
ATF- $3.49
Stanadyne Performance Formula - $10.99
Bob Ayers's Avatar
Bob Ayers
ATF is a great diesel injector cleaner....
Old Feb 8, 2004 | 10:15 AM
TurboTuff's Avatar
TurboTuff
And affordable...
Old Feb 8, 2004 | 10:51 AM
Mike 84's Avatar
Mike 84
Fellas,
We have equipment at work that has tens of thousands of hours and/or hundreds of thousands of miles. This equipment gets nothing but straight #2 diesel fuel and has had no abnormal fuel system problems. Do you also add this in the dead of winter when its really really cold out?I would think that adding ATF when really cold out would help to thicken your fuel,thus giving you a tank full of slush.Fuel system additive to prevent fuel gelling I can understand. ATF - stop the nonsense!!!
Old Feb 8, 2004 | 12:02 PM
TurboTuff's Avatar
TurboTuff
In the winter i add an anti-gel....in the summer ATF.
At my work in the diesel forklifts they run ATF in the fuel all year round with no problems.
The crap you buy that is for this actually dries out the rings???
Is this a ploy?
Because brittle o-rings = $ to repair.
Old Feb 12, 2004 | 01:04 PM
Garlicbreath's Avatar
Garlicbreath
Where can you buy Off-Road diesel at?
Old Feb 12, 2004 | 01:27 PM
TurboTuff's Avatar
TurboTuff
Off-Road Diesel??
You mean colored diesel?
You need a farm licence or Heavy equip certificate...
But don't get caught with it in your truck on or of the road!
Old Feb 12, 2004 | 03:24 PM
Garlicbreath
will it work in a kerosene heater? What about will kerosene work in a diesel?
Old Feb 12, 2004 | 07:11 PM
  #28
ditch witch's Avatar
ditch witch
GB,
Contact a local fuel supplier, farm supplier. Or just contact a "gas station" and ask then where you can purchase "Off Road Diesel". You'll probably have to get ahold of a manager to get the answer. Often they deliver in large quanities. Usually 300 gal. tanks or larger. But may offer a pump at their location and you can go in with a 5 gal. container and purchase as you choose. They may also ask questions at to its use.
Old Feb 12, 2004 | 09:22 PM
  #29
Dave Sponaugle's Avatar
Dave Sponaugle
I would think the smell of off road diesel would be terrible in a kerosene heater.
Kerosene will work in a diesel but you will have low power from it.
Jet A is great in a kerosene heater, no smell at all, but a little pricey at the airport.
Used to stop at a truck stop in Colorado that had #3 diesel in the summer. Great power but boy did it gell up easy.
In WVa off road fuel being used on the highway will cost you 10 dollars a gallon x tank capacity or 2000 dollars, which ever is greater. Off road fuel has no highway use tax paid on it, any more it is low sulphur fuel just like the highway use fuel is, so the only difference is the tax and the red dye.
Most truck stops have off road diesel for the reefer guys to run in their refridgerated trailers.
Old Feb 13, 2004 | 08:19 PM
  #30
MRZ's Avatar
MRZ
Yes, diesel mix will burn in a 'torpedo' style heater but makes everything reak and your eyes really burn-
Kerosene goes good in the tank in the winter to keep things moving...
