starter not cranking
Old Jan 30, 2004 | 12:10 PM
rmckeen's Avatar
rmckeen
it was minus 59 the other night had my 2002 f350 7.3l plugged in but didnt notice my block heater cord was broke , it cranked over a few times and the batteries just died , i tried boosting it and it almost went but no go, so i fixed the cord hooked up a battery charger and left it a couple hours, now i turn the key everything seems to light up and go through the sequence but now my starter is not cranking over ........any suggestions????
Old Feb 3, 2004 | 12:47 PM
thauto99's Avatar
thauto99
starter
I am having the same problem with a F550 flatbed and I do not want to put a new starter in it if that is not the problem. If anyone has any suggestions, let us know, thanks.
Old Feb 4, 2004 | 12:43 AM
96P_Stroke4x4's Avatar
96P_Stroke4x4
Smokin'
check to see if the wires going to the starter are loose, and also check and clean off the battery terminals. wouldn't hurt to check the fuses as well
Old Feb 4, 2004 | 10:10 AM
thauto99's Avatar
thauto99
I pulled the starter out yesterday and tested it, nothing. Replaced the starter, good to go, thanks for the help.
Old Feb 6, 2004 | 09:17 AM
rmckeen's Avatar
rmckeen
starter
i put in a new starter and a new battery , and this solved the problem , i guess ford starters are only good for a year and a bit...........
Old Feb 6, 2004 | 10:32 AM
bilder12's Avatar
bilder12
It seems the starters on the Ford diesels are really sensitive to being overworked. They heat up internally and take a crap. I suppose it is considered parts sales security - decision of the manufacturer. There are aftermarket starters that seem to hold up much better and work better too.
Malcolm --- your thoughts here please.
Old Feb 6, 2004 | 02:51 PM
JMorton's Avatar
JMorton
My starter is stock, never had a problem. I don't see a whole lot of them come in. It's just a machine, some break, some don't.
River19
13
Sep 9, 2014 02:55 PM
Pheadrus
44
Jan 12, 2014 12:45 PM
Frankiea87
Jan 3, 2014 09:00 PM
Rocketattack
Dec 21, 2008 09:32 AM
killer4x4
Feb 19, 2006 02:01 AM
