TRUCK NOT STARTING
Old Jan 3, 2014 | 08:02 PM
Frankiea87's Avatar
Frankiea87
TRUCK NOT STARTING
hey guys, its freezing here in NY.. 3 degrees currently, a few weeks ago i had a new starter installed and batteries and FICM upgrade, i used the truck all day today and its been sitting now for 4 hours, i went to go move it in my driveway and it wouldnt start, no crank, nothing, batteries are good, i didnt hear the starter engage? Also went to plug in the block heater and it trips my GFCI in the garage, i tested truck plug with ohmmeter and not getting any continuity between hot, neutral,ground ( so that meens theres nothing wrong?) extension cord is working fine, untill i plug it in- it trips.. im fed up with this truck!!!
Old Jan 3, 2014 | 08:23 PM
73fan's Avatar
73fan
After sitting only 4 hours at that temp it would fire right up if your starter engaged. If it's not even clicking I'd check starter connections.
Old Jan 3, 2014 | 08:24 PM
BLADE35's Avatar
BLADE35
when its that cold I cycle my GP 3 times truck starts right up
But Figure out the block heater
You should have Continuity Plus should Ohm out at 15ohms IIRC was the Average between HOT and Nuetral so Check this out
Here is My Thread there been a Few Guys Post Ohm Values in it for Block heater
https://www.ford-trucks.com/forums/1...-stratigy.html
Mine ohmed High around 35 IIRC but I Ultimatly had a Bad Cord at the time of this thread
Old Jan 3, 2014 | 08:55 PM
Frankiea87's Avatar
Frankiea87
couldnt go to bed without looking at the truck again lol.... curled underneath and noticed the heater cord wasnt plugged into the block,, it was dangling covered in snow/ice!!! so my mechanic when he installed the starter must of never plugged it back in good enough..... plugged it in and its working!
Also the truck started after i held the key on, not sure if the temperature is so damn cold ( -3 now) that the block heater being plugged in for 5 min warmed it up to help it start or something else made it start? idk but its running and stayin warm!!! lol sorry for the PITA thread.
Old Jan 3, 2014 | 09:00 PM
Fal-308-Win's Avatar
Fal-308-Win
Glad ya found it.
Douglas DC-9
Jan 25, 2022 11:02 PM
BLADE35
Jan 24, 2014 08:25 PM
got2befast
Feb 10, 2011 07:48 PM
torino_gt
Nov 5, 2007 05:11 PM
Ed the outdoorman
Sep 9, 2004 03:17 PM
