Zf-sources
Old Jan 30, 2004 | 01:45 AM
willd's Avatar
willd
Zf-sources
I may be in the market for a zf 5 speed. What are good donor trucks for 2wd. I have 78-F150 with a 4spd NP 435 right now. Will I need a different clutch system and bellhousing. Will this tranny hold up to moderate use and towing behind a stout 400?
Old Jan 30, 2004 | 02:04 AM
Boss_358's Avatar
Boss_358
It should work just fine. Get yourself a 460 transmission. I wanna say from the years 88-97. I can not confirm that but it is in the ballpark. Sorry, I'm a little tired right now.
Old Jan 30, 2004 | 11:40 AM
loudfords's Avatar
loudfords
There is a conversion for a 460 ZF to mechanical clutch, I'll have to dig up the link. The ZF came in S5-42 form from 87-95, and in S5-47 form from 96-97. Take a look in F250s and F350s. You can go to www.car-part.com to search your area. Durability should be fine with your setup.
EDIT: Ok, here is a link on the clutch conversion, it has a couple sub-links. https://www.ford-trucks.com/forums/s...threadid=96008
'97f350supercab
Dec 4, 2016 08:06 AM
XBAJBUSX
23
Oct 22, 2014 06:43 PM
fisherman_chuck
Aug 28, 2013 08:42 PM
brickie
Apr 24, 2009 11:24 PM
redranger1
Mar 8, 2002 11:36 PM
