Zf5 to zf6 swap
After what my 42 has been through lately, and survived, I'm not changing it. I just rebuilt it and forgot how simple they were. And how easy to rebuild. The only fancy tool you really must have is a dial indicator and feeler gauges. For setting up synchro hub clearances and the bearing preload.
I'm just about ready to order an aux transmission though for behind the transfer case. That will make a huge difference in RPM at highway speeds and they have been around a long time. Anyone with enough power to wreck a zf42 probably gets mileage that is so crappy they don't do very much highway driving with it so who cares?
and iv read in numerous places its rated for 520'#s
ZF 6 Speed ZF S6-650 Specs
in case anyone else was curious
If you like fast, don't get a ZF-6. They are great transmissions for pulling, because of the close ratios, but if you are trying to do a WOT 0-60, or something similar , there is 1 more gear shift between here and there.....
I have driven lots of both, and the ZF-6 is great, just not for drag racing
Sorry for bringing up an old post , but I am very interested in doing the ZF6 swap. This thread addressed a few things for the swap and if this all there is to it, I am going to do the swap.
If any one has anything more to add that may be a problem, I would appreciate knowing what it might be.
Thanks,
Thanks,
