Electrial starting problem
Old Jan 29, 2004 | 03:18 PM
RedneckF-150's Avatar
RedneckF-150
I have been working on my friends 87 F-150 4.9 lately, and the truck will not start with the key. It can be turned on(radio, heater, ect.) but it will not crank. To start it, you have to pop the hood and start it with a screwdriver on the solenoid. All I need to know is what two wires to connect to engage the starter. This help would be appreciated.
Old Jan 29, 2004 | 04:44 PM
Mil1ion's Avatar
Mil1ion
There should be a wire on the starter relay (small terminal) that is fed from the key ignition circuit.
The terminal should have an *** I *** near it.
87 ?
Unless Ford moved the solenoid to being mounted on the starter.
Old Jan 29, 2004 | 04:48 PM
torquemeister's Avatar
torquemeister
On my '86, it had the same problem (intermittently) when I bought it. It's a blue & red wire running from the ign switch to the "I" post on your starter solenoid. Since my problem was pretty random, I just installed a push button ign and ran my own wire through the firewall to the solenoid. Hope this helps.
TM
Old Jan 30, 2004 | 10:13 AM
Franklin2's Avatar
Franklin2
If you want to try to fix the problem, then I would look at your neutral safety switch(either on the side of the auto tranny or on the clutch pedal).
There is another poster with the same problem, and it looks like he might have a problem also with his ignition switch actuating linkage.
With a voltmeter, test the blue/red wires going into the neutral safety switch. If you spring the ignition switch to start, and you have no voltage at the neutral safety switch, then there must be something wrong at the igntion switch and or the linkage.
Old Jan 31, 2004 | 02:05 PM
RedneckF-150
Quote:"It's a blue & red wire running from the ign switch to the "I" post on your starter solenoid. Since my problem was pretty random, I just installed a push button ign and ran my own wire through the firewall to the solenoid."
How exactly would I set this up, torquemeister?
Old Jan 31, 2004 | 02:26 PM
Mike W's Avatar
Mike W
Connect +12 thru a fuse to the switch and back to the solinoid terminal.
Old Jan 31, 2004 | 02:28 PM
RedneckF-150
By the way, I tested the clutch switch. It's fine. I just need to know how to hook up the wires.
Which terminal?
Old Jan 31, 2004 | 04:23 PM
Mike W's Avatar
Mike W
The same one you touch the screwdriver to.
tyson555
1997 - 2003 F150
23
Oct 5, 2023 03:14 AM
SamG65
2004 - 2008 F150
Mar 21, 2012 08:44 PM
longacre5
1997 - 2003 F150
Jan 19, 2012 02:40 AM
hammerin16ds
Modular V8 (4.6L, 5.4L)
Feb 12, 2011 01:14 AM
jrank
2004 - 2008 F150
Feb 20, 2009 01:30 AM
