On my 72 F-250 there are two or three inline fuseable links at or near the alternator-voltage regulator area. If one of these fuses goes bad,what is the correct replacement part and do I need to replace the wire as well or just the fuse? This is after I find the reason the fuse failed and repair that problem before replacing the fuse. Thanks for the imput.
"bowties in the rearview mirror"
Thanks Million,I will start looking at my local parts supplier for a new wire.The old wire wore thru at the alternator and finally shorted itself out which explains why I keep getting power spikes . What started me looking was that the headloghts would dim way down for a second then come right back up. Thanks again.
HELP! I just bought an 88 Bronco, 302. The tach jumps up and down about 1500 rpms. It doesn't matter whether I'm setting at a stoplight or driving down the road. It also seems to do it at a consistent interval (15 seconds). This morning, it wouldn't start and I notice that the fusible link was completely melted from the solenoid to the link block. Does anyone know if these problems are interrelated? I could sure use some help!!
