Help need more power
Old Jan 29, 2004 | 01:35 AM
crudemover's Avatar
crudemover
Unhappy Help need more power
I have a 1999 F150 with 4.6L Romeo 150 heads
I have installed 3.73 limited slip diff. Hypertech power tuning, 160 degree thermostat, and cold air intake.
I am looking for more power but don't have $2100.00 to drop on a supercharger.
I was looking at replacing the stock injectors with a larger injector. Can this be done? Will I have to change the computer set points? and what size or how big can I go.
Please help on any suggestions on how to wake this puppy up.
Old Jan 29, 2004 | 05:18 PM
openclasspro's Avatar
openclasspro
unless you are making more than 330rwhp the stock injectors are fine
Old Jan 29, 2004 | 08:16 PM
DeckedoutF150's Avatar
DeckedoutF150
do exhaust and headers. what are you doing with your truck?? i pull a 18 foot ranger bass boat and it pulls the boat fine. i have air intake, exhaust done to mine. i found a place to do a custom "Y" pipe on my truck fopr under $200 with 18" long and 3 and a half inch round slash cut chrome tips
Old Jan 29, 2004 | 08:18 PM
DeckedoutF150
i also do not have a muffler. sounds great!!!!!
Old Jan 31, 2004 | 11:31 PM
LxMan1's Avatar
LxMan1
Ditch the 160 thermostat unless you want to wear out the engine prematurely. They are designed to seal better (rings) at 195 than 160.
Old Feb 1, 2004 | 11:28 AM
DeckedoutF150
what about a 180 thermostat
Old Feb 1, 2004 | 10:11 PM
V10KLZZ71S's Avatar
V10KLZZ71S
any thing below 180 and the pcm goes into open loop which is it does not take reading from sensors and just goes by some preset settings in the pcm, not good.
Old Feb 4, 2004 | 06:56 AM
2000BLK54's Avatar
2000BLK54
Supercharger....about all you can do. Cams are sort of a bolt on job along with ported heads. Not much else that's cheap....
Old Feb 4, 2004 | 11:03 PM
garydvan's Avatar
garydvan
ALSO A 160 DEGREE THERMOSTAT CAUSES THE FUEL TO WASH THE OIL OFF THE CYCLINDER WALLS.
Old Feb 5, 2004 | 08:00 AM
Bob Ayers's Avatar
Bob Ayers
Absolutely go back to the 195 thermostat!!!
If your truck isn't fast enough, normally it's a lot cheaper, safer, and more reliable, to buy something already designed and built to run faster.....Just my $0.02!!!
Old Apr 2, 2004 | 10:02 AM
weck11's Avatar
weck11
New Exhuast, 4.11's, NOS
RIKIL
Sep 8, 2011 10:21 PM
AndysFords
13
Sep 2, 2009 06:55 PM
DrFord
Nov 21, 2007 01:26 AM
Ford Truck Racer
16
Oct 31, 2006 08:48 AM
Bigcordogg
Mar 26, 2002 04:16 PM
