Power question
Old Mar 25, 2002 | 10:59 PM
Bigcordogg's Avatar
Bigcordogg
Power question
I would like some help,
I own a 1995 F-150 long box 4x4 standard cab i have a 302 under the hood. Anyways heres my questions:
1: How can I increase my power in my engine?
2: Do chip really work?
3: Would powered fuel injectors work?
Thank
Cordogg
Old Mar 26, 2002 | 10:05 AM
jim henderson's Avatar
jim henderson
Power question
A lot depends on what kind of power you want. Do you want high end power or lowend torque. In either case there is a lot of speed equipment for the 5.0 since they are in Mustangs etc.
The usual hot rod techniques apply, ie better intake, better exhaust are first and usually easiest and cheapest to do. Then we get into the engine where all kinds of expensive mods are possible. Or just stick a blower or N2O on it and be done with it. It all depends on what kind of power you want like I said.
Chips sometimes work. But usually they make the most difference when you mod the engine. They change shift points, advance the timing, increase the dwell of the injectors etc. All of this is good, IF your truck is setup to take advantage of the changes.
I have no idea what you mean by powered injectors.
Good Luck, been there, done that, spent way too much time and money and busted all my knuckles getting there.
Jim Henderson
Old Mar 26, 2002 | 03:27 PM
DeGideo's Avatar
DeGideo
Power question
The easiest way to enhance your 302's power would be to upgrade it's exhaust system,and swap the stock air filter&airbox out,and replace it with an open element K&N air filter. A "chip" might also work,but adding one to your truck's computer will mean you have to put 91 (or higher)octane gasoline in your gas tank. If you don't your 302 might get a lot of detonation which can cause serious problems.Plus,it will cost you more money at the gas pumps.Your stock injectors&throttle body should not be changed,unless you plan a lot more upgrades.
Old Mar 26, 2002 | 04:16 PM
madman666's Avatar
madman666
Power question
Portagepd86
Dec 20, 2014 08:05 AM
croc58
Jan 4, 2013 02:52 PM
61ford4u
May 30, 2008 07:30 PM
Cheshire Cat
1966 - 1977 Early Broncos
Mar 30, 2004 01:05 AM
FordTruck1
May 28, 2002 12:38 AM
