Sponsored by: Auxito
"whine at start up"
Old Jan 28, 2004 | 03:39 AM
v8xploder's Avatar
v8xploder
"whine at start up"
the last two of three times ive started my truck 2000 f-150 4.6 4x4 it has a loud whine from under the hood for 5 to 45 seconds. Sounds lke a belt , kinda...or possibly the power steering pump, any way its been really cold for the 2 days or so about -2 to a high of 3 degrees all day and night. is it the cold?has any one had this problem?? thanks
Old Jan 28, 2004 | 11:33 AM
grizz5675's Avatar
grizz5675
My 2001 150 lariat w 5.4 does the same thing and with mine i am sure its the serp belt they get stiff in cold weather ,I wouldnt worry about it to much but check the condition of your serpentine belt.
Old Jan 28, 2004 | 12:04 PM
superrangerman2002's Avatar
superrangerman2002
It's your power steering pump complaining about the cold, all PS pumps do this to certain degrees.
-10F this morning and my was whining pretty good too.
I've often wondered if it would be benficial to change out the Atf in the PS pump to a true synthetic.
I can't remeber for sure but I think that the PS pump uses Mercon 3.
Old Jan 28, 2004 | 12:41 PM
v8xploder's Avatar
v8xploder
yea thats what i thought, its been so cold that i didnt even want to pop the hood and look! i found some posts on some people saying its there transmission whining at start up. its probobly just the p/s. if the p/s uses the same mercon thats in the tranny, isnt that synthetic?
Old Jan 28, 2004 | 02:18 PM
leroys4wd's Avatar
leroys4wd
I was going to ask the same question, my '03 F-150 does it too, it's been below freezing here for a couple weeks and it started making a noise under the hood for a short while at cold startup. I had a Toyota 4x4 that did this same thing at cold startup and it was the timing chain rattling, this sounds just like that. My Toyota engine was toast because of it, hope the Ford isn't experiencing the same problem!
Old Jan 28, 2004 | 09:21 PM
fordborn's Avatar
fordborn
Mine does the same thing when the temp gets down near zero. It's the power steering fluid being real thick. I have been trying to find out if there is any other power steering fluid to use but it all looks the same. Lucky for me it doesn't get that cold here very many days.
Old Jan 29, 2004 | 02:02 AM
Smokem''s Avatar
Smokem'
Chalk up two for me in the whine department. Both my trucks do the whine on startup. Talked to ford and they said it was ok and not to worry, Although i am worried because i don't see any other vehicles doing this? maybe a design flaw, or is it just something you have to live with?
Old Jan 29, 2004 | 06:56 AM
superrangerman2002
I guess one solution is getting a heated garage.....
Old Jan 29, 2004 | 07:12 AM
leroys4wd's Avatar
leroys4wd
mine sounds more like the sound an alternator makes when the bearings are bad, is that the 'whine' everybody else is hearing?
Old Jan 29, 2004 | 07:21 AM
superrangerman2002
If upon starting in really cold weather, and you turn the steering wheel, and the whine changes, it's the PS pump.
Old Jan 29, 2004 | 08:29 AM
Racerguy's Avatar
Racerguy
The idler and tensioner bearings have been known to make noise sometimes too. It can be pretty hard to pinpoint exactly where the noise is coming from.
Old Jan 29, 2004 | 08:42 AM
leroys4wd's Avatar
leroys4wd
the noise itself doesn't bother me because as stated above, it goes away in about 30 seconds. I just want piece of mind that it isn't doing any damage. From the posts I've read here, it sounds like everything is ok.
Old Jan 29, 2004 | 11:58 AM
MrBSS's Avatar
MrBSS
I think I'm going to use the Mobil 1 Synthetic trans fluid when I change my PS fluid. It meets Mercon specs, which is what Ford calls for there, but not Mercon V, which my transmission needs.
FX4 Fighter Pilot
19
Nov 29, 2010 03:57 PM
stein78
1997 - 2003 F150
Feb 16, 2009 06:22 PM
one_wicked_element
Modular V10 (6.8l)
Dec 3, 2007 12:22 AM
FordMan190
1983 - 2012 Ranger & B-Series
May 7, 2004 04:30 PM
