Voltage meter going wacky
Old Jan 27, 2004 | 08:27 PM
1990Fordf150v8's Avatar
1990Fordf150v8
Tonight while I was out in my truck at a stop light the voltage meter was going wacky and the radio was going on and off (after market) while I had the heater fan on high with the hedlights on, but there was no change in RPM's. What do you think is going on? Is it the volage reg. thingie? Cause it's been doing it for a month but it starts up fine. Let me know what you all think. Thanks again.
Old Jan 27, 2004 | 09:24 PM
crossf-150's Avatar
crossf-150
Are the lights dimming out? You might be putting too much load on the alternator. do you have a system in the truck "IE: amps, speakers and such?"solunds like maybe when you are in Idle maybe the alternator isnot making enough revolutions to keep up with the demand of your electrical system or maybe your alternator/battery is maybe getting weak. My truck puts out 14.2 volts cruising unless I have the A/C , headlights and such on. And then it drops to about 13.1 volts in idle. do you have a way to check and see what your alternator is putting out with it in Idle?
blais42
13
May 9, 2014 07:34 AM
whalebus2112
Jun 22, 2013 09:19 PM
Wavehogger
2009 - 2014 F150
Mar 24, 2011 02:58 AM
Pwy_FireCapt
May 7, 2010 06:10 PM
