Sponsored by: Real Truck
Wacky Speedometer issue
Old May 7, 2010 | 04:44 PM
Pwy_FireCapt's Avatar
Pwy_FireCapt
I'm new to the board...
I have a 2003 F250 7.3l diesel 4wd...
2 days ago my speedometer started reading 70-80mph while doing 35-40. Then, when i slowed to a stop it pegged to 100, and as I began to drive, it went back to the 70-80 range.
Today when I turned it on, it was at 0mph and would not respond until I got to about 35mph, then repeated the first symptoms.
No ABS light came on, odometer is working, and tach is working.
Should I start with the VSS?
Thanks in advance for any help you can give...
Pwy_FireCapt
Old May 7, 2010 | 06:10 PM
Furian's Avatar
Furian
You Keep What You Kill
Yeap! If that's not the problem, then you may have issues with the PCM.
Welcome to FTE!
Mpauly
6.7L Power Stroke Diesel
13
Jan 9, 2014 09:20 AM
Kirk.ri
Nov 28, 2013 06:15 AM
Milwaukee1979F150
Dec 2, 2009 09:45 AM
Chargerkid
May 2, 2004 04:13 PM
