e4od - no forward gears
Old Jan 27, 2004 | 08:16 PM
foote's Avatar
foote
Question e4od - no forward gears
Please help with any info that will get me going - I have a 92 F450 with a 7.3 and a E40d in it - we had some shifting problems around 100k but trased it to a wire harness problem for the speed sensors - GREAT - now in the midle of the intersate we lost all forward gears - reverse is still there!! - This is what I have been told and have read into so far and if anyone can direct me to the truth that would be great - I have been told that if you have nothing at all in any of your fwd. gears then it is not electrical. Good - I have reverse so the shaft internally cannot have broken - So what I have come up with is a "false nuetral" if you will - Other than replacing the valve body - is ther any other pressure valve assembly or something that could be leaking internally and if not is there a way to check the valve body for correct pressure in each gear, or for that matter any way to check any thing with just the pan off - i.e. the clutchs etc.. HELP any thing would be of assistance.
Old Jan 29, 2004 | 09:51 PM
norcalseahawkfan's Avatar
norcalseahawkfan
Well I'm having the same problem with my 94 F250 W/E4OD. I am pulling the tranny this weekend.
E99F2504x4
Jul 17, 2022 01:50 AM
miashley150
17
Mar 21, 2016 09:48 PM
miashley150
Mar 9, 2016 10:19 PM
Pennywise7
2004 - 2008 F150
Aug 26, 2015 02:17 PM
robw4242
Jul 27, 2015 09:42 AM
