I picked up a complete 460 today out of a 78 Mercury Marquis. It had an automatic transmission which I was able to get for $50 so I decided to go ahead and grab it and cross my fingers it's a C-6.
I think you might want to check your source of info biz4two. I'm DEFINITELY NOT an expert, but I believe alot of non-OD autos in at least F250s up through at least '89 are C6s. Correct me if I'm wrong. Supposedly the C6 out of an '83 will swap out with a non-OD auto in an '89. Check the cross refs.
Looks like I ended up with a C-6 afterall. For $50 I figured I couldn't go too wrong.
I read that the truck transmissions had a deeper pan. Other than this is there any difference between the truck (4x4) version of the C-6 and the car version? I'm wondering about the tail shaft. I know I can unbolt the tail and bolt my transfer case adapter to it but I'm wondering if the shaft itself will work with my NP205.
Originally posted by LT1Z2ave I think you might want to check your source of info biz4two. I'm DEFINITELY NOT an expert, but I believe alot of non-OD autos in at least F250s up through at least '89 are C6s. Correct me if I'm wrong. Supposedly the C6 out of an '83 will swap out with a non-OD auto in an '89. Check the cross refs.
You might want to ask the author: "By Bob Ferguson" about the info posted. I was just pointing towards a link that I found in the Tech Articles section.
