Sponsored by: Real Truck
Rear Diff
Old May 28, 2002 | 09:36 PM
Outpost22's Avatar
Outpost22
Rear Diff
Had the oil changed last week and the service guy showed me that my rear differential fluid was "milky" and full of bubbles. Even though the truck has only 16+k miles on it he said that it should go 50k without a change to the dif oil, and I might have something going on thats breaking down the oil (it has the LS option). What do you guys think?
Old May 28, 2002 | 09:47 PM
FortyFords's Avatar
FortyFords
Rear Diff
Outpost,
My thoughts are water or condensation within the dif.
Did you go through any flooded areas or roads in the past?
Did you have trouble with the ls when the truck was newer?
Did some one mix synthetic with standard gear lube?
Me I'd change it ,be safe than sorry!
Just My $.02
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old May 28, 2002 | 09:48 PM
Monsta's Avatar
Monsta
Sit. Stay.
Rear Diff
>...the service guy showed me that my rear differential fluid was "milky" and full of bubbles.
The only time that I've seen "milky" oil is when it has been contaminated with water.
>...he said that it should go 50k without a change to the dif oil,
You should never have to change your rear diff. fluid unless it is submerged in water. (so says the manual) Or, as it looks in your case, contaminated with water.
Old May 28, 2002 | 09:52 PM
4x4x4x4's Avatar
4x4x4x4
Rear Diff
Water maybe?
Condensation,clogged vent,four wheeling deeper than the vent,many short trips with very little hwy.use to warm up and evaporate moisture.
I'm not saying it is,but I'm throwing these possibilities out there in case it is water.
Old May 28, 2002 | 09:57 PM
slammer's Avatar
slammer
Rear Diff
I'd be really careful with this problem outpost... In my "young and dumb" years, I had an 81 F250, that I "used"..I went through water, mud, snow, everything imaginable and one day, 150 miles from home, the axle sheered off... Long story short.... when they took it apart, the gear lube was milky white.... $1500 later (this was in 82)I was back on the road...
Change the lube....
Old May 28, 2002 | 10:00 PM
FortyFords's Avatar
FortyFords
Rear Diff
Man Talk about an echo!
Guys do we look like high pressure salesmen or what?
Hint! Hint! Monsta!
Rich
not with rocks
Old May 28, 2002 | 10:14 PM
Outpost22's Avatar
Outpost22
Rear Diff
The only "water" I can think of going through is once I launched my B-I-L boat in Lake Mead and had to back in up to my rear axle to get it launched. That might explain it....
Old May 28, 2002 | 10:25 PM
NoMo's Avatar
NoMo
Rear Diff
The lake would do it- especially if the axle was hot when you submerged it. Change the lube as soon as possible.
BTW, that's a pretty good oil-changing place! Not many will actually check the fluids they are supposed to check.
Old May 29, 2002 | 06:59 PM
Outpost22's Avatar
Outpost22
Rear Diff
Well , I had the dif oil changed today...it was quite painless:7
Thanks for all the advice
Old May 29, 2002 | 07:26 PM
4x4x4x4's Avatar
4x4x4x4
Rear Diff
When they added new lube did they also add friction modifier?
I once had a rear axle cover weep repaired under warranty at the dealer and before I got home I knew they forgot to add a few ounces of the stuff.The clutches aren't smooth around corners without it.
Old May 29, 2002 | 10:10 PM
redranger1's Avatar
redranger1
Rear Diff
we had a 94' one ton dually that the top of the cover rusted out on it. the reason was that we didnt drive it that much(sold in 2000 w/ 65,000 miles on it)and condensation built up in it. so, when the pan gets removed look at the top of the cover to see if it is all rusty and you will find out if this is or isnt the cause.
-nathan
Old May 30, 2002 | 09:20 AM
Outpost22's Avatar
Outpost22
Rear Diff
>modifier?
Yes they did. I called them first to see if they had it, and they purchase it directly from Ford. Thanks to these forums, I was ahead of the curve on this one
Old May 30, 2002 | 09:23 AM
Outpost22's Avatar
Outpost22
Rear Diff
cstanley44
Jun 26, 2012 02:02 PM
sand_fiend
Oil & Lubrication
15
Jul 11, 2011 04:46 PM
Wildfire532FB
35
Jan 17, 2011 06:06 AM
PSDLOVER
13
Sep 3, 2007 04:22 PM
TCTOOL
Jan 18, 2002 09:29 PM
