Oil & Lubrication
Ticking at cold start
Old Jan 29, 2004 | 04:50 PM
therion's Avatar
therion
Originally posted by jessfactor
i too have a ticking sound and was told it was probably lifter noise. what exactly is that. i know what lifters are, but what is causing the ticking and is there any danger in that. i only have 100k miles and want this engine to last a long time. thanks. -jesse
Mines been ticking too lately. 63,000 miles. It seems normal becuase when you rev it up it sounds better.
Old Jan 29, 2004 | 10:17 PM
TallPaul's Avatar
TallPaul
Originally posted by MJEmerson
someone told me that MMO is basically ATF...anyone know?
That's interesting. A mechanic recently told me that Rislone Engine Treatment is basically ATF.
I remember my '84 F150 after 150,000 miles and about 13 years would occasionally get a very loud lifter tick (or so that's what I thought it was) on start up in cold weather. After a while it would quiet down. And that engine had Rislone every oil change. Hmmmm.
Old Jan 30, 2004 | 10:32 AM
oppy's Avatar
oppy
This is from a previous post by Flash:
MMO is a mineral oil carrier used to deliver solvents and chlorinated hydrocarbons. It's basically a 20wt oil with solvents to thin the oil and has a flashpoint about 350F. Years ago when upper lubes were considered useful, MMO was a good choice. Valve recession is no longer a problem in modern engines using fuels that no longer contain tetraethylene. Considering the composition of todays oils and the complexity of the formulations, I would suggest caution using any additive who's formula is as old as your grandfather. You might just upset the additive base in your oil.
I'm sure MMO is fine for oiling air tools, etc. but there's no way it's going in my crankcase.
Old Jan 30, 2004 | 03:16 PM
therion's Avatar
therion
The only additive that i know of that is good is LubeControl - It really works!. http://www.lubecontrol.com/
BatistaBomber12
2004 - 2008 F150
Jul 21, 2016 11:11 AM
ncred02
6.2L V8
Feb 19, 2015 04:20 PM
Buck268
2009 - 2014 F150
Nov 21, 2014 03:53 PM
TrukProblemz
2004 - 2008 F150
Feb 10, 2014 02:51 PM
Stangfire
1997 - 2003 F150
Jul 8, 2011 06:32 AM
