Hey there Ford enthusiasts, i need your help once again, here's the deal, i recently purchased a 79 1 ton 4x4 with a 460 already in it. i bought the truck aware of the engine problems, the truck had a rear sump oil pan on it, i believe it was a ford oil pan because the gasket looked stock. i need to find another pan for the motor because two of the connecting rods exited the crankase through it . just wondering where to find a cheap aftermarket or if anyone could tell me what the rear sump was used on in ford applications. thanks again fte'ers
look at mid 80's up 2 wheel & 4 wheel drive trucks & vans with 460's if it looks different but will work get the pick up tube also as for your pan if the flange area is not damaged why not just weld yours up.
It was for a 85 f259 4x4 I put the motor in a 79 f150 2wd every thing fit great igot a pan and a pick up tube for the oil pump so I new there would be no problems & 1 main cap bolt with the stud on it to bolt thepick up tube on.
