ignition
Old Jan 28, 2004 | 01:29 PM
badass truck's Avatar
badass truck
ignition
how do i get the ignition switch out of my dash? i tried sticking a lil peice of wire threw the hole but didn't work, any suggestions. its a 1979 f250 4x4
thanks
Old Jan 28, 2004 | 01:38 PM
Mil1ion's Avatar
Mil1ion
It has to be in the accessory position before you put the paperclip in the hole and turning the tumbler C/Clockwise
Old Jan 28, 2004 | 02:01 PM
custom79's Avatar
custom79
It is easier (at least for me)to unscrew the outside ring off and pull the entire unit out of the dash and unplug the wires. Then do as Dennis said to remove the actual "key" ignition.
Old Jan 28, 2004 | 02:48 PM
Mil1ion's Avatar
Mil1ion
The thread seems like Deja Vu, to me
Old Jan 28, 2004 | 10:52 PM
badass truck
yea, i have the entire dash out, i'm trying to start my truck and i just want to be able to take it out of the dash and leave that part plugged in so i can try and start it. and another question is, i'm not getting any spark, what you guys think that prob is ground?
Old Jan 28, 2004 | 11:00 PM
Mil1ion's Avatar
Mil1ion
You're attacking this at the wrong end.
You need to verify power at certain location before you yank out the ignition switch.
Starter relay
*I* circuit on starter relay
Power at coil + terminal
Signal at coil - terminal
Power at Modulator
Signal at Modulator
Spark at Coil
Spark at plug wires
Spark @ sparkplugs
Old Jan 28, 2004 | 11:08 PM
badass truck
well i did a down to frame restoration. i just left the motor on it though didn't rebuild it. i put the cab back on and now i'm not getting spark or anything. i just set the dash up their for the time beeing and pluged in the ignition switch and thats not even making it turn over or anything at all. so what do you think it could be then? the battery is hooked up and i'm not getting spoark at the plugs haven't had time to look anywhere else yet
thanks
Old Jan 28, 2004 | 11:28 PM
Mil1ion's Avatar
Mil1ion
bma2001
Sep 2, 2013 09:25 PM
blkmesamtman
Oct 1, 2011 02:33 PM
pknute
Jan 29, 2006 01:55 PM
79 250 lariat 4x4
28
Feb 29, 2004 09:15 AM
ITDave
Sep 28, 2003 02:28 PM
