Wiring connectors
Old Jan 26, 2004 | 10:30 AM
kdewise's Avatar
kdewise
Wiring connectors
I need to find some wiring connectors or some good replacements for the window lift motors and the door front speaker.
Any two wire connector of good quality will work for the window lift motor, but the radio connector must fit the sodder point on the speaker coorectly.
Thanks for any help.
Old Jan 26, 2004 | 01:24 PM
frederic's Avatar
frederic
Any connectors you need... source out of a junkyard. Literally, a dime a dozen. Feel free to mix and match as you see fit. My F350 has connectors in it from Ford, Cadillac, Chrysler, Honda, Chevy, and two Hyundai connectors.
Hey, whatever works
To splice, solder properly, cover with heat shrink tubing, then you're good to go.
Old Jan 26, 2004 | 05:18 PM
jasonwho's Avatar
jasonwho
Hi. I can't help on the window wires, but as for the speakers, I suggest you check out Metra at www.metraonline.com. I bought two for $2.99 each at Auto Zone. It allows you to not have to cut the stock wiring. If the speaker terminal is different, then cut the adapter wiring and not the truck wiring. You might need to pull your new speakers out and put the old ones back in if you sell it.
Good luck,
jasonwho
CharlieLed
Apr 25, 2013 09:51 PM
Rick Keesee
Feb 6, 2013 12:28 PM
Forrest_F150
2004 - 2008 F150
Aug 9, 2005 08:14 PM
hendrix89
May 6, 2004 12:21 PM
