Fords first 4x4 super cab?
All depends on your skill with a torch and a welder.
You would have to shorten the frame and rear driveline and, of course, have a short box. I don't think it would be too difficult but you I wouldn't trust myself to weld a frame.
We had a discussion a while back about the short box Supercab 4x4s. Someone swore Ford never made them. I have seen a couple in town which means either they did make a few or several people have made this conversion.
on
1 Post
Originally posted by MarkManz
Is cutting and welding on a frame a good idea?
If it's done properly it will be just as strong as the rest of the frame, in some cases even stronger. If you have it done take it to someone who specializes in frame work, not just anyone who can weld. In addition to making a proper weld/joint in the frame it's very important to make sure your measurements are dead on, so boht sides are exactly even, and that it's all aligned right when it's welded.
mean351stang
01-07-2016 10:38 PM
idaho211
07-27-2014 12:07 PM
