Caliper ?'s
Old Feb 1, 2004 | 09:55 AM
somethingurnot's Avatar
somethingurnot
Help with my ford!!
I have a problem i picked up a 76/77 ford 3/4 ton. The truck came with dual piston calipers. I cant fit my 15 on the front with out hitting the calipers. I need help and i have pix of my setup. What do i have for options to make my 15's fit. I need to go the cheap way. I found 2 inch spacers but they want 400 CDN for 2. Is there a part # to go with single pistion calipers. Will a single fix the problem. The truck will never see the hiway. Any help? The frony is a Dana 44 high pinion!
Old Feb 1, 2004 | 09:59 AM
LxMan1's Avatar
LxMan1
3/4 tons were designed for 16 or 16.5 wheels.
Old Feb 1, 2004 | 10:00 AM
somethingurnot
I know but the truck came with 15x 10's and new 38's! Im trying to make the 15s work!
Old Feb 1, 2004 | 10:52 AM
LxMan1's Avatar
LxMan1
Is it 5 lug? Most 3/4 tons that I have ever seen are 8 lug and I have never seen a 15" 8 lug wheel
Old Feb 1, 2004 | 10:53 AM
somethingurnot
Its a custom 15x10 with 8 hole. I know its odd. What do u think about the calipers?
Old Feb 1, 2004 | 10:58 AM
LxMan1's Avatar
LxMan1
Good question. How far out would you have to space it to clear the caliper?
Old Feb 1, 2004 | 11:01 AM
somethingurnot
2 inches and 400 bones. I can find a single piston caliper for 28 bones new. Can i switch the the duals for the singles? They guy is not sure they are the right ones. Do u guys know where i can find some used spacers cheap?
Old Feb 1, 2004 | 11:07 AM
LxMan1's Avatar
LxMan1
I'm not sure on the calipers, Hopefully someone else here can help you. Sorry
Old Feb 1, 2004 | 01:10 PM
ranger429's Avatar
ranger429
I do not think you will find a single piston caliper to fit on a 3/4 ton setup. The single piston bolt's up and attaches a completely different way than the 3/4 ton does. The 3/4 ton attaches with a top and bottom bolt that the caliper slides on, the 1/2 ton has the wedge mount. Next to impossible conversion there.
the rim is a custom made 15x10 with 8 lug pattern? Never seen that, you could possibly have someone make custom adapter's but I was never very big on those for safety reason's
Upon further thinkin of the spacer setup you would probably need about 3" or 4" spacers to clear the caliper from the wheel
Old Feb 1, 2004 | 02:50 PM
firstonraceday's Avatar
firstonraceday
My 77 F-250 has factory single piston calipers however, it's two wheel drive and also has 16" wheels. I don't know if you kind find any 3/4 ton calipers that will fit under 15" wheels. A word of caution, the one thing you don't want on a motor vehicle is a cobbled together brake system.
Old Feb 1, 2004 | 03:03 PM
wick246's Avatar
wick246
"I need to go the cheap way."
I think the cheap and safest way is to just get the correct wheels and tires. Good luck...
Old Feb 1, 2004 | 03:28 PM
ranger429's Avatar
ranger429
does it also have the wedge and clip that goes on the bottom side of the caliper with the single bolt that retains it? If so it is the light duty suspension, same caliper as a 1/2 ton
I know of no manufacturer that makes a bolt on single piston caliper to replace a dual piston caliper setup. Can you say lawsuit
I have to agree with wick246, if you can't do it a safe way than discard the wheels and tires and get the correct one's
Old Feb 1, 2004 | 05:53 PM
somethingurnot
This truck will only ever see a mud pit!
Old Feb 1, 2004 | 06:33 PM
ranger429's Avatar
ranger429
Oh well that is different! There are probably never any spectator's standing around that would mind getting run down by a size 38 because of a busted wheel spacer
Best of luck
Old Feb 1, 2004 | 07:31 PM
Matts72's Avatar
Matts72
You can get 16 inch steel wheels for $40 a piece. You should not even attempt to use a single piston caliper on a 3/4 ton, it is very dangerous, single pistons do not have the power to stop a much heavier truck.
