Exhaust size?
Old Jan 24, 2004 | 10:56 PM
nudgey's Avatar
nudgey
Exhaust size?
Apologies for the newbie question. Can anyone advise me what size exhaust i should put on my 1985 f100 302 efi? Currently it has a small- ish exhaust which sounds like a vaccum cleaner, it is about too fall off anyway, I wan't people to know what's up front. I don't want to put extractors on it (insurance will knock me back). I don't wan't to go too loud just something in between. Any advice would be much appreciated. Thanks in advance.
Chris
Old Jan 24, 2004 | 11:16 PM
fordeverpower's Avatar
fordeverpower
2.5 inch and flowmaster muffler.
Old Jan 25, 2004 | 05:11 PM
nzabka's Avatar
nzabka
fordeverpower is right about the pipe size. Nothing below 2.5" for pipe.
The bigger the pipe, the more reduced your back pressure will be, thus giving you a small increase in horsy's and a little bit better gas mileage.
Old Jan 26, 2004 | 04:56 PM
mopar's Avatar
mopar
NOTHING BIGGER THAN 2.5 INCH & DUEL EXHAUST.
2 1/4 WOULD BE THE BEST CHOICE FOR DUEL EXHAUST.
IT ALL DEPENDS ON HOW MUCH HP YOU HAVE.
LOG ON TO FLOWMASTERMUFFLERS & DYNO MAX FOR MORE INFO.
Old Jan 27, 2004 | 12:10 AM
NorthernFord's Avatar
NorthernFord
I'm running 2.5" duals, no headers, flowmaster mufflures, and no cross-over pipe, seems to have a real bark at 2000-2500rpm
Old Jan 27, 2004 | 12:12 AM
NorthernFord
yes but by going to big you will have no torque down low in the rpm range and this could make it difficult to get off the line.
Old Jan 27, 2004 | 12:31 AM
nudgey's Avatar
nudgey
Thanks NorthernFord.What's it sound like idling?
Chris
Old Jan 27, 2004 | 11:54 AM
NorthernFord
it's got a nice rumble with lots of bass but no popping, it has a very smooth sound to it.
Old Jan 27, 2004 | 05:07 PM
mopar's Avatar
mopar
ACCORDING TO BORLA, FLOWMASTER,DYNOMAX & MEGAFLO EXHAUST COMPANYS, THEY ALL RECOMMEND 2.0 INCH DUEL EXHAUST OR 2.5 INCH SINGLE EXHAUST FOR THE 302.
A 2.5 INCH DUEL EXHAUST WOULD HAVE A DEEPER TONE, AND A CROSS AT LEAST 13 INCH IN FRONT OF MUFFLERS. 17 INCH PREFERED.
A FRIEND HAD A 351 FUEL INJECTED F-150 4X4 STOCK MOTOR OTHER THAN MSD IGNITION & K&N AIR FILTER, 1990 MODEL, IT RAN 16.1 @ 92MPH WITH 2.5 DUELS, FLOWMASTER DELTA FLOW 40 SERIES MUFFLERS AND CROSSOVER. THE EXHAUST GOT DESTROYED ON A ROCK WHILE 4 WHEELING. THE SHOP THAT REDONE IT RECOMMEDED 2 1/4 INCH DUELS WITH A CROSSOVER & FLOWMASTER DELTA FLOW 40 SERIES MUFFLERS.
THE TRUCK RAN A LITTLE QUICKER. 15.9 @ 94 MPH. SAME TRACK
( BRISTOL TN.) TRUCK HAD 79,000 ON FIRST RUN AND 87,000 ON SECOND RUN. OUTSIDE TEMP. WAS 85 DEGREES FIRST TIME AND 87 DEGREES THE SECOND TIME.
Old Jan 29, 2004 | 12:03 AM
NorthernFord
yes and that is due to torque, but you have to remember that you horsepower/torque curve changes when you modify any engine components, and if you do not modify your drivetrain to match, then your vehicle will run slower, in my case I have all the torque I could want due to 4.11:1 diff ratios and a t-18 tranny, and I needed a little more hp to motivate my tires in the mud.
Old Jan 29, 2004 | 12:05 AM
NorthernFord
[QUOTE]Originally posted by mopar
[B]ACCORDING TO BORLA, FLOWMASTER,DYNOMAX & MEGAFLO EXHAUST COMPANYS, THEY ALL RECOMMEND 2.0 INCH DUEL EXHAUST OR 2.5 INCH SINGLE EXHAUST FOR THE 302.
you can't always build you truck to aftermarket specs, you have to build it for the way that you will use it.
Old Jan 29, 2004 | 01:22 AM
Matts72's Avatar
Matts72
2.25" duals, through single chamber 40's or 3 inch single through a 28 inch glass pack.
Old Jan 29, 2004 | 02:25 AM
shortblock2000's Avatar
shortblock2000
use 2.5 inch pipe connected to a 10 inch CHAMBER PIPE, 24
inches long and you will get an exhaust rumle like nothing you have ever heard before....I fabricated this unique item with lot of trial an error
Old Jan 30, 2004 | 08:41 PM
nudgey's Avatar
nudgey
thanks guys. I will study the information you have given me. I know have a good idea what is needed.
Old Feb 2, 2004 | 04:25 PM
mopar's Avatar
mopar
Smile
[QUOTE]Originally posted by NorthernFord
[B][QUOTE]Originally posted by mopar
[/QUOTE
This is info for the way you will use it!!!
Its also by many years of trial and error... Suggestion was for, to access different companys and other people, to determine what works for the vehicle and type of driving it will encounter..........
rodriguezfords
Jan 25, 2008 05:03 PM
rbjam
15
May 24, 2007 01:32 PM
SMF Speed&Custom
Apr 13, 2005 03:36 PM
nuclearmonster
Jul 22, 2004 07:03 AM
