rear door problems
Old Jan 24, 2004 | 06:23 PM
chixon's Avatar
chixon
rear door problems
does anyone know if automatic locks when the vehicle is started was and option or an additional item. and also how, or can i unplug something to make the rear door not auto lock so i can only use the key to open it....the reason being that the lock or motor or somehting in the rear door makes a wierd sound when it tries to lock...alomst like a machine gun or something....any help would be appreciated
Old Jan 24, 2004 | 06:47 PM
FTE Herman's Avatar
FTE Herman
The lock solenoid needs to be replaced in your rear door(s). Your owner's manual should provide instructions to de-program the autolock feature if you desire. You can disconnect the solenoid as you say but you can't unlockthe rear doors with a key, there is no tumbler on the rear doors, only the fronts.
Old Jan 24, 2004 | 07:04 PM
PaulC's Avatar
PaulC
I think he means the tailgate. I would just replace the lock solenoid. Not hard to access.
Old Jan 25, 2004 | 01:48 AM
chixon's Avatar
chixon
thanks guys...will check that...
Old Jan 25, 2004 | 03:19 PM
FTE Herman's Avatar
FTE Herman
Ah, yes. The liftgate. Silly me. He said door not doors.
IIGood
Oct 26, 2015 05:35 PM
Roc53ky
Aug 8, 2015 06:29 PM
Greatcarsx4
Nov 30, 2014 10:59 PM
jake_whitman
Oct 10, 2014 11:02 AM
skiddy465
2009 - 2014 F150
Jun 15, 2014 07:17 AM
