Should I drop the pan?
Old Jan 24, 2004 | 03:34 PM
tsdrallyer's Avatar
tsdrallyer
This is a new one on me! What do you think? I tried to check the engine oil yesterday and found that only the cable part came out of the dipstick tube with the handle! The flat metal part where you check the oil level was gone! I ran a magnet down the tube all the way to the oil level and didn't get it, or at least it didn't come back out. Will something that big and heavy have a risk of doing any damage under any foreseeable conditions, or should I just get a new dipstick and forget about it?
Old Jan 24, 2004 | 06:50 PM
FTE Herman's Avatar
FTE Herman
I'd go for the new dipstick. If you have a magnet on a flexible wand you might try fishing for it with the drain plug out. It's in the bottom of the pan and will do no harm.
Old Jan 24, 2004 | 11:49 PM
buzzard's Avatar
buzzard
I can't imagine what it would entail to "drop the pan" on one of these.....it's not easy on my '68 F250 so I doubt it'd be a breeze on these Expy's. I'm thinking along the same lines as hkiefus, it's probably down in the bottom just hanging out (its weight should keep it away from the crank) and I doubt it could work its way up as the oil pump has a big screen on it.
Scary thought nonetheless.
Old Jan 27, 2004 | 08:14 AM
dalejarrettfan's Avatar
dalejarrettfan
i would try a coat hanger through the drain plug if the magnet isn't strong enough or if it's a stainless cable
Old Jan 27, 2004 | 02:44 PM
nickalbu's Avatar
nickalbu
I thought my engine stick was just flat mettal with nothing on the end but the Trany stick is a cable with a plastic tab on the bottom with marks for oil level?
Old Jan 27, 2004 | 03:16 PM
dalejarrettfan
d@mn i think you're right...shows how much i pay attention to it.....lol
Old Jan 27, 2004 | 04:40 PM
tsdrallyer's Avatar
tsdrallyer
I got the new replacement dipstick today and it's not the same type. Instead of cable with flat metal on end, it's all flat metal wth corkscrews in it and it's made of two peices riveted together. Much harder to get in and out. I can't see any reason why it couldn't be made in one piece plus handle to make it easier to insert and retract, and to insure reliability. Where do those engineers come up with these ideas... recycle bins?
Old Jan 28, 2004 | 09:56 AM
buzzard's Avatar
buzzard
They've gotta continually change things to justify their existence. I'd bet many hours and much more $$$ went into that design.
gowild0706
24
Nov 29, 2017 09:51 AM
Derrick Stiriz
Jan 26, 2017 09:26 PM
1992 f350 4x4 7.3
Sep 7, 2014 05:06 PM
nlemerise
May 29, 2012 11:53 AM
andrew1
Nov 13, 2010 09:18 PM
