Decoding part numbers on carbs
Old Oct 19, 2004 | 05:16 PM
himmelberg's Avatar
himmelberg
I need two decent Holley 94 type carbs for my 3 deuce setup on the old y-block. My joblot catalog just showed up with a number of options. Could someone tell me which of the following is a replacement for the 3 bolt Holley 94/2100 type of carb?
8rt-9510-R
B3Q-9510-A
B6C-9510-R
C2tz-9510-DR
I posted this in the carb forum but never have had much luck with answers there. Mostly directed at newer stuff.
Thanks, himmelberg
Old Oct 20, 2004 | 07:11 PM
286merc's Avatar
286merc
As I said on another forum the only EE1 style carb on that list is the 8RT 1948-53 truck carb. Altho it has a different air horn the car style will swap over. It should also have the extended throttle shaft.
hotstuff
401, 477, & 534 SD Engines
Oct 23, 2015 03:41 PM
94.5PWRSTRK
Mar 2, 2010 03:44 PM
himmelberg
Jan 4, 2004 07:05 PM
The Undertaker
Dec 21, 2003 06:52 AM
Holly carb
Aug 29, 2003 03:07 PM
