Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
tig welder question
Old Jan 23, 2004 | 05:45 AM
uk1050's Avatar
uk1050
tig welder question
i have an arc welder and i seen in harbor frieght a tig welding
gun that hooks up to your arc welder with the dense quick
connects. the gas is ran off of my wire welder tank. has anyone ever used one of these they are only 40.00 bucks my main use would be for cleaning up welds that are no so perfect and i want to weld different metal. is it worth 40 dollars....
Old Jan 23, 2004 | 04:27 PM
markking77's Avatar
markking77
A few things. You wil have to scratch start the arc, you won't have a variable output (no foot pedal), and you will need pure argon for tig. You can't use the common Mig C25 gas. Other than that it will work, and does make a good cheap introduction to tig.
Old Jan 23, 2004 | 05:55 PM
uk1050's Avatar
uk1050
thanks alot for the info. help me alot.
Old Jan 24, 2004 | 06:43 PM
01ford250's Avatar
01ford250
I am new to the welding buisness and wanted to know if you could help me with selecting the correct one. I would like to get one for house hold project and ect. Am i going to need to get any tanks or what not. Just wanted to know if you could suggest a "starter" or something inbetween. Thanks
Old Jan 24, 2004 | 07:35 PM
hdgapeach's Avatar
hdgapeach
By far the easiest welding method to learn and get almost instant success and satisfaction is the MIG method. For household projects and simplicity of use, I'd recommend one of the smaller units that are in the hobbiest or light duty class. Miller and Lincoln both have excellent smaller units that are household current powered, either 110 or 220 volts. If you have access to a dryer outlet (220v), I would recommend one of the 220 units. You can use gas or flux-cored wire with MIG welding. My personal preference is Lincoln's SP-175Plus. Has a pretty good duty cycle and continuous output controls, which means you can fine tune your settings rather than accepting only specific notched settings on the dial. Go to Lincoln's web site when you got several hours to kill. You'll be amazed at all the info you will have access to. www.lincolnelectric.com
Drop me a line if you have anything else you think I could help you on.
Old Jan 24, 2004 | 09:35 PM
01ford250's Avatar
01ford250
Thanks a bunch..........That was some great help, I will look into it and let you know if i have any more questions. Which i'm sure i probably will.
Old Jan 25, 2004 | 06:12 AM
uk1050's Avatar
uk1050
i have a nice mig welder and have used tigs in the past.
tigs are very expensive. i was going to get the attachment for my
arc welder. but thats when i thought i could just use my mig gas and regulator. its bad enough to drive 30 miles for one tank exchange not really worth another tank and regulator. i'll stick to
my mig. thanks for the help......
Old Jan 28, 2004 | 09:15 PM
Tom41ks's Avatar
Tom41ks
tig help
I don`t want to be discouring,but TIG welding has more to do with practice and experance than any other welding process .When you see TIG on Tv it looks easy.The best way to learn how to weld is to find a votech with night classes.Do not buy equipment that you aren` traned to use
Old Jan 29, 2004 | 06:12 AM
uk1050's Avatar
uk1050
why not, i learn at home by practice.....
Old Jan 29, 2004 | 12:42 PM
Mike W's Avatar
Mike W
I am self-trained. I went from arc to oxy/act to mig to tig. Just read a lot of books.
Old Jan 29, 2004 | 01:01 PM
Torque1st's Avatar
Torque1st
Posting Legend
Working with high powered equipment can be, lets rephrase that, IS VERY dangerous. Reading books helps, as do classes etc. Unfortunately with this type of equipment you often don't get a chance to learn from a mistake, you are just dead, -and possibly those people that were around you.
People often skip, or do not understand, the safety information in books and manuals so a classroom environment with an instructor is often the best and safest method to learn. Your life is worth a little time and $$.
Another unfortunate fact is that skilled workers often make a task "look" easy, -and safe!
1951flatheaddave
48
Apr 21, 2012 12:50 AM
tractormanbill
Nov 20, 2011 12:18 AM
al3x
16
Sep 11, 2009 09:57 PM
jimhackney
24
Mar 30, 2007 09:30 AM
sancochojoe
Garage & Workshop
Apr 11, 2004 01:32 PM
