rhodes lifter question, preload.
Old Jan 21, 2004 | 07:08 PM
dsloanscott's Avatar
dsloanscott
i am just getting ready to put fire to my freshly built 400. i ran into a problem though. i forgot to prime my rhodes lifters. what i was planning on doing was cranking the motor without the plugs in while turning the oil with a drill. is there anything wrong with doing this? secondly, does the oil pump shaft turn clockwise or counterclockwise. easy to find out but i might as well ask. thanks. derek.
Old Jan 22, 2004 | 07:26 AM
ranchero77's Avatar
ranchero77
welcome derek. hydrualic lifters usually don't need priming, does rhoads recommend that their's do? they have high bleed rates and I wouldn't think it would matter.
taking the plugs out is a good idea, it is not a good idea to crank over your fresh motor until you get oil pressure. first use the 5/16" hex tool and turn clockwise. have a valve cover off so you can see when you have oil pressure. good luck and post back with how you liked these lifters.
RoryTheFerret
Modular V8 (4.6L, 5.4L)
Apr 6, 2016 04:54 PM
Butchashop
New Member Introductions
Dec 6, 2013 03:23 PM
dynamic
Rhode Island Chapter
26
Aug 25, 2010 08:44 AM
Jrock909
Feb 3, 2007 10:57 AM
d44hd
Jan 23, 2004 10:47 PM
