97 Turbo Powerstroke help
Old Jan 20, 2004 | 06:26 PM
1necowboy's Avatar
1necowboy
I have posted this before, with no luck , I will try to make it as exciting as the cam sensor that you all suggested and fixed my problem thanks,
My diesel starts okay, but as soon as it does and I push on the accelarator my whole engine rumbles.
Going down the road it does it still, however if I take it out of gear and coast it doesnt. But even out of gear if I push down on the accelarator its rumbles.
Any suggestions.
Old Jan 20, 2004 | 07:57 PM
muff's Avatar
muff
can you be moore specific about the rumbling sound?
Is the engine missing, stumbling or is it just a noise
louder the normal?
Is it using oil?
Old Jan 20, 2004 | 08:30 PM
78fordman's Avatar
78fordman
Might be a bad injector, i do not know if there is a way to test them, but i would check that, and would remove them cas if you have them, they are going to clog up and be nothing but problems, save your self the greef. Could be a injector seal, are you loosing or gaining any fluids, primarily coolant and oil?
Old Jan 20, 2004 | 11:06 PM
kevinrf250's Avatar
kevinrf250
Is your truck a stick? If so it sounds like the dual mass fly wheel is bad. I have driven two trucks with bad fly wheels and they make a rumbly/racheting sound, it is kinda hard to describe though. This is my guess though. One of the trucks, the owner thought that is was an injector, but it turned out to be the fly wheel. Hope this helps some.
Old Jan 21, 2004 | 01:42 PM
1necowboy's Avatar
1necowboy
thanks turns out to be a cracked transfer case housing , I think that is the part name , I cant seem to find any diagrams.
Thanks
Old Jan 21, 2004 | 06:00 PM
78fordman's Avatar
78fordman
try searching under extension housings.
Old Jan 22, 2004 | 12:08 PM
1necowboy's Avatar
1necowboy
Thanks 78fordman, I will, I will let you know how it turns out fyi
best regards cowboy
