Sponsored by: Real Truck
Temp
Old Jul 3, 2002 | 09:14 AM
rgs108's Avatar
rgs108
Temp
I have a class A motorhome with and 89 ford 460 carb. motor.
My question is what should the temp range be?
It wants to run 230 on flat and has gone to 250 when going up a grade.
Old Jul 3, 2002 | 12:40 PM
Y2K350's Avatar
Y2K350
Temp
230 degrees? Not good.
250 degrees? Very bad.
should be 195 to 205
2000 F350SD,RC,5spd man,V10, Front Leveling Kit,4.30 gears
Old Jul 3, 2002 | 05:50 PM
FortyFords's Avatar
FortyFords
Temp
[updated:LAST EDITED ON 03-Jul-02 AT 06:52 PM (EST)]Rgs108,
Thats not good!
I been around motorhomes awhile ,since 86 ,have and had 460's that like to run hot!
Here are my suggestions!
Get a ford diesel thermostat,they are the same operating temp range,same design, but when they open up the flow rate through the stat is twice as much lowers temps by some 10-15 degrees.
I would also chk that your fan hub(controlled by temp) is working correctly,when it kicks in should sound like a roar.
unless you have electric fans! make sure their working
I hope you have aftermarket gauges,water ,tranny temps
Rich
Old Jul 3, 2002 | 06:33 PM
therigwelder's Avatar
therigwelder
Temp
jobguy
Escape & Escape Hybrid
Feb 28, 2012 04:17 PM
nurse47557
1997 - 2003 F150
Jan 15, 2005 10:02 PM
restorit
Electrical Systems/Wiring
May 9, 2002 10:32 PM
dave thomas
Oct 1, 2001 11:07 AM
brucef
Feb 21, 2001 08:08 PM
